Нет не снимал, сегодня попробую.
Переустанавливаю moode, хочу попробовать раздельно запитать платы.
Джампер ничего не даст!
Может здесь видна причина?
S Y S T E M P A R A M E T E R S
Date and time = 2019-03-17 05:03:28
System uptime = up 15 minutes
Timezone = America/Detroit
moOde = Release 4.4 2018-12-09
Host name = moode
ETH0 IP = 192.168.1.189
ETH0 MAC = b8:27:eb:ff:dd:2d
WLAN0 IP = unassigned
WLAN0 MAC = b8:27:eb:aa:88:78
WiFi country = US
HDWR REV = Pi-3B+ 1GB v1.3
SoC = BCM2835
CORES = 4
ARCH = armv7l
RASPBIAN = 9.8
KERNEL = 4.14.98-v7+
KTIMER FREQ = 100 Hz
USB BOOT = enabled
Warranty = void
ROOT size = 2.9G
ROOT used = 75%
ROOT avail = 705M
FS expand = not expanded
MEM free = 32 MB
MEM used = 72 MB
Temperature = 52.6°C
CPU GOV = performance
MPD SCHDPOL = TS
P3-WIFI = On
P3-BT = On
HDMI = On
ETH0 CHECK = On
MAX USB CUR = Off
UAC2 FIX = Off
ETHPORT FIX = Off
SSH server = Off
LED0 = on
LED1 = on
C O R E S E R V E R S
PHP-FPM = load
NGINX = 1.10.3
SQLite = 3.16.2
C P U L O A D
CPU %usr %sys %idle
all 0.77 2.30 55.74
0 0.00 0.00 100.00
1 0.00 0.50 99.50
2 0.51 3.59 21.54
3 2.56 5.13 1.03
P R O C E S S L O A D
PRI RTPRIO COMMAND %MEM PSR %CPU
29 - mpd 2.1 3 49.0
19 - mount.ntfs 0.4 3 4.7
19 - sysinfo.sh 0.2 0 1.6
19 - php-fpm7.0 1.2 2 1.3
19 - usb-storage 0.0 2 0.7
19 - kswapd0 0.0 1 0.5
19 - systemd 0.4 0 0.2
19 - worker.php 0.6 0 0.2
19 - kthreadd 0.0 0 0.0
C L O C K F R E Q U E N C I E S
arm = 1400 MHz pwm = 0 MHz
core = 400 MHz emmc = 200 MHz
h264 = 300 MHz pixel = 25 MHz
isp = 300 MHz vec = 126 MHz
v3d = 300 MHz hdmi = 163 MHz
uart = 48 MHz dpi = 0 MHz
SD card = 50 MHz
S Y S T E M V O L T A G E S
core = 1.3563V
sdram controller = 1.2500V
sdram I/O = 1.2500V
sdram chip = 1.2250V
U I C U S T O M I Z A T I O N S
Theme = Standard
Accent color = Emerald
Alpha blend = 1.0
Adaptive background = No
Background image = No
Playback history = No
Extra metadata = Yes
Artist list order = Artist
Compilation rollup = No
Compilation excludes = greatest hits
Cover search pri = Embedded cover
Hi-res covers = Auto
Pixel ratio = 3
Cover backdrop = No
Cover blur = 20px
Cover scale = 1.25
A U D I O P A R A M E T E R S
Audio device = Pi2Design 502DAC
Interface = I2S
Hdwr volume = Controller detected
Mixer name = Digital
Output stream = S16_LE / 44100
ALSA version = 1.1.3-5+rpi3
SoX version = 0.1.2-2
Volume knob = 62
Volume mute = Unmuted
Bluetooth controller = Off
Airplay receiver = Off
Spotify receiver = Off
Squeezelite = Off
UPnP client = Off
DLNA server = Off
Rotary encoder = Off
Encoder params = 100 2 3 4 5
Crossfeed = Off
Parametric EQ = Off
Graphic EQ = Off
Auto-shuffle = Off
Autoplay = Off
MPD crossfade = Off
M P D S E T T I N G S
Version = 0.20.20
Volume control = software
ALSA device = hw:0
SoX resampling = disabled
SoX quality = very high
SoX multithreading = off
Audio buffer (kb) = 4096
Buffer before play = 10%
Output buffer size (kb) = 81920
Volume normalization = No
DSD over PCM (DoP) = no
Replay gain = off
B L U E T O O T H S E T T I N G S
Bluetooth ver = 5.49
Bluealsa ver = Turn BT on for version info
Speaker sharing = No
Resume MPD = No
A I R P L A Y S E T T I N G S
Version = 3.2.2
Friendly name = Moode Airplay
ALSA device = hw:0
Volume mixer = auto
Resume MPD = No
Output bit depth = S16
Output sample rate = 44100
Session interruption = no
Session timeout (ms) = 120
Audio buffer (secs) = 0.0
S P O T I F Y S E T T I N G S
Friendly name = Moode Spotify
ALSA device = default:CARD=sndrpihifiberry
Resume MPD = No
Bit rate = 160
Initial volume = 0
Volume curve = Logarithmic
Normalization pregain = 0
S Q U E E Z E L I T E S E T T I N G S
Version = 1.8.7-1052 "DSD/SRC enabled"
ALSA device = hw:0
ALSA params = 80:4::1
Output buffers = 40000:100000
Task priority = 45
Codec list = flac,pcm,mp3,ogg,aac,alac,dsd
Resume MPD = No
Other options = -W -D 500 -R E -S /var/loca
M O O D E L O G
20190317 044806 worker: - Start
20190317 044806 worker: Successfully daemonized
20190317 044806 worker: Integrity check ok
20190317 044807 worker: Session loaded
20190317 044807 worker: Debug logging (off)
20190317 044807 worker: - Platform
20190317 044808 worker: Host (moode)
20190317 044808 worker: Hdwr (Pi-3B+ 1GB v1.3)
20190317 044808 worker: Arch (armv7l)
20190317 044808 worker: Rasp (9.8)
20190317 044808 worker: Kver (4.14.98-v7+)
20190317 044808 worker: Ktyp (Standard)
20190317 044808 worker: Gov (performance)
20190317 044808 worker: Rel (Moode 4.4 2018-12-09)
20190317 044808 worker: Upd (None)
20190317 044808 worker: MPD (0.20.20)
20190317 044808 worker: USB boot enabled
20190317 044808 worker: File system not expanded yet
20190317 044808 worker: HDMI port on
20190317 044808 worker: File check ok
20190317 044808 worker: - Network
20190317 044808 worker: eth0 exists
20190317 044808 worker: eth0 (192.168.1.189)
20190317 044808 worker: wlan0 exists
20190317 044808 worker: wifi country (US)
20190317 044808 worker: wlan0 SSID is blank
20190317 044808 worker: eth0 addr exists, AP mode not started
20190317 044808 worker: wlan0 address not assigned
20190317 044809 worker: - Audio
20190317 044809 worker: ALSA outputs unmuted
20190317 044809 worker: ALSA card number (0)
20190317 044809 worker: Audio out (I2S audio device)
20190317 044809 worker: Audio dev (Pi2Design 502DAC)
20190317 044809 worker: ALSA mixer name (Digital)
20190317 044809 worker: MPD volume control (software)
20190317 044809 worker: Hdwr volume controller exists
20190317 044809 worker: - Services
20190317 044809 worker: Reset renderer active
20190317 044811 worker: MPD started
20190317 044811 worker: MPD scheduler policy (time-share)
20190317 044811 worker: Configure MPD outputs
20190317 044811 worker: MPD output 1 ALSA default (on)
20190317 044811 worker: MPD output 2 ALSA crossfeed (off)
20190317 044811 worker: MPD output 3 ALSA parametric eq (off)
20190317 044811 worker: MPD output 4 ALSA graphic eq (off)
20190317 044811 worker: MPD output 5 ALSA bluetooth (off)
20190317 044811 worker: MPD crossfade (off)
20190317 044811 worker: - Music sources
20190317 044811 worker: USB source (media)
20190317 044811 worker: USB source (TOSHIBA EXT)
20190317 044811 worker: NAS sources (none configured)
20190317 044811 worker: - Miscellaneous
20190317 044811 worker: Volume level (0) restored
20190317 044811 worker: Maintenance interval (21600)
20190317 044811 worker: Screen saver activation (Never)
20190317 044811 worker: Watchdog started
20190317 044811 worker: Ready
20190317 044956 worker: Job mpdcfg
20190317 045145 worker: Job rescanmpddb
Что это значит?
Так и должно быть. Mute это когда значение громкости на минимуме.
Меня вот это больше заинтересовало.
Что это значит и что с этим делать?
Rudaeyuriy, а шляпа как собрали всё хоть раз работала или как собрали и тишина? Можете сделать фото хорошего качества низа шляпы, может какая деталька отпала? И ещё, посмотрите оптика светится? Ещё можно прозвонить от пайки разъёма до другого конца кабеля цифрового, чтобы отмести этот узел.
Через bnc постоянная тишина, оптика светится, через rca слушаю. Прозвонил все пайки разъемов: оптика, rca aes звонятся bnc нет.
https://drive.google.com/file/d/123HJk-1RWg2B4AMn-rwMP41VsAPCdLdo/view?usp=drivesdk
В этом месте звоню?
https://drive.google.com/file/d/1JlAUbi7qqCaSm_bgK_2neOyp_bs5WkRM/view?usp=drivesdk
https://drive.google.com/file/d/15aDiHbH2-UM8tdS0Lz5jNHtkMxr_WinN/view?usp=drivesdk
Бнц не там звоните, посмотрите с верху платы сзаде бнц, выходят две ноги центральная жёлтая и потолще рядом светлая.
Там тоже не звониться
Эти две пайки большие где вы щупы держите, я так понимаю это сам корпус bnc припаян к плате, а контакты рядом две небольшие точки пайки ну и звонить их надо иначе.
Один щуп держите на пайке, а другим на выходе разъема…
Звоните правильно, один конец тестера к центральному контакту бнц, а второй к центральному контакту кабеля подключенного к этому бнц (тот который в ЦАП втыкаете)
Две большие капли припоя это просто сам разъём держится, скорпусом контакта у него по-моему нет.
Так звониться, корпус тоже звониться
Оптика горит красным при работе?
Заглушку снять и посмотреть…
Так звониться, оптика светит красным
Второй контакт тоже прозвоните, на кабеле корпус рца разъёма
Надо мерять вольтаж на выходе bnc, должно быть в районе 1V, главное не закоротить. Странно, что компетентные люди молчат…
Могу ошибаться, я не спец!
Чота не соображу что ещё посоветовать, она у Вас с цифры ещё не разу не играла, ЦАП исправный есть возможность проверить его по спдиф входу с этим кабелем?
Если все прозванивается, я бы посоветовал накатить Волюмио и посмотреть как работает с ним. Муд достаточно проблемная штука, постоянно какого-то рода хрень всплывает у людей. Делов - на 10 минут вместе со скачиванием и заливкой имиджа. Тем более, что с монтированием шары вам можно не заморачиваться - играете с флешки.
Вообще не замечал за moode никаких проблем, заводится с пол пинка.
