То есть у тонармов со съемным шеллом есть и преимущества)))
Oleg_Tchernavski
4мин
у меня только мс))))))))
Oleg_Tchernavski
4мин
что такое 60сек?
столиков небыло никогда))))))
на римского-корсокго во внутрь почти не заходил
Ну, в клубе и 15 лет назад уже не очень здорово было)) Ничего не потеряли)))
А «60 секунд» - интеллектуальная забава для любителей ЧтоГдеКогда… значит, обознался))
LFD AUDIO
"We think of LFD that the goal of the Audio Engineering always must be to achieve the highest possible playback quality, we give and stick to it, that in order to optimize the playback quality of our equipment in addition to the scientific approach and subjective factors must be taken,. The personal opinion is always ultimately decisive. But on the other hand, we put as much emphasis on scientific approach. We measure the objective variables are the same as our design philosophy, which is characterized by minimalism and the dictates of the shortest signal paths. "
- Dr. Richard Bews, Professor Malcolm Omar Hawksford , LFD Audio.
LFD Audio believes that it is possible to perfect a product if and easiest when the basic circuits are kept as simple as possible. Dr. Brews in the 80 years of scientific staff of Be Yamamura. Therefore, Dr. Brew looks rather small in the tradition of Japanese high-end companies such as Kondo. Their tradition informs his approach to this day. In addition to the minimalism among others, the extensive selection of passive components is one of them. The subjective assessment is of paramount importance, as well as the reliability of the components. It has been shown that the best possible components for a specific position in the circuit will behave differently than similarly good components. For example, it is usually not possible, a certain resistance type in the whole circuit to be used. Each point in the circuit must receive exactly the type of resistance that gives the best subjective results. This selection process is also applied to the capacitors. This iterative procedure is very time consuming and has the effect that product development is methodical and slow. There is no other simple way. But at the end of this persistence in return brings better playback quality.
The boards of the LFD audio products are always star-earthing. The signal paths are kept as short as possible and are 5 times shorter than those of other manufacturers. LFD Audio is no advocate for the use of circuit boards, for it has been found that, the use of high quality cable is less deterioration as a result the signal paths of the boards. Consequently, in LFD Audio products to be found more cable lines, as like its products from competitors. Each cable installation will be subjectively evaluated for the best cable for this connection to find. Often find single core cables and multi-core cable at the same time use.
Feedback is used as little as possible, if the distortion is low enough. LFD Audio is not of the opinion that the minimum distortion amplifier concepts have subjectively sound better. In general it is better to a higher percentage of harmonic distortion have low atomic number, as lower distortion with a higher atomic number.
Power plays an important role in an audio amplifier design and the design requires the utmost care. LFD Audio has been able to be universally valid, that decoupling of interference from the public power grid directly on the spot within an audio amplifier has to be done with a power supply, which is characterized by low impedance to high frequencies. The ground connection to the power amplifier must be designed in a straight and low. Otherwise, unwanted coupling occurs with the music signal to be amplified. The technical design of the power transformer has a direct influence on the music playback quality. LFD Audio found in transformers that causes a high packing density and consequently uniformly executed Lagenbewicklung a direct improvement in the quality of reproduction.
Minimalism is the LFD Audio has prescribed for reasons of sound, also has its “special features”. There is no preamp output for subwoofer, only in “emergencies” balanced inputs / outputs , the amplifier give a light thump when you turn away and there is no remote control. It is not intended that there will ever be remote controls. Dr. Brew has a very clear opinion on this: everything is installed additionally complicates the circuit and is therefore omitted from sound reason. Because, as postulated above: only the simplest circuit can be optimized!
The appearance of the LFD audio devices could be described as loving. But certainly not highend. You have to say that LFD Audio uses less than 10% of the cost of parts for the chassis. A value is almost laughable in comparison to the competition. But if you value a nice cover, you’ll have no problem finding suitable products from other manufacturers. It LFD Audio is no comparison when it comes to the cost of all other product installed eder Kompenten. For the “inner values” using only the best!
How could I show hopefully elect LFD audio, for good reasons, this very labor-intensive product development and manufacturing process, with more than a few, but for the best components, each component is evaluated for its sonic potential, pathway if handwired required. Now, one might suspect that these would be the highest quality attainable, would buy LFD Audio certain parts of Asia favorable or operated by outsourcing low-wage countries. Therefore, all finished LFD Audio under its control, in England in our own factory. Only way to offer the highest quality at a reasonable price.
LFD Audio is the statute " statutes to product requirements and compliance with traditional values given "to bring to the customers, vendors and their product marketing approach in detail.
Сайта http://www.lfd-audio.co.uk уже нет
а у кримсона его вроде вообще никогда небыло,
чел наверное досих пор стационарным телефоном пользуется)))))))
Ну уж нет — https://crimsonelectronics.com/
а точно…
когда он мне выскакивал (этот сайт)
воспринимался как дистрибьютор его…
вот:
http://www.austinhifi.com/crimson.html
дизайн сайта один
Howard Popek
Да)
Посмотрел а его группа в фб уже все
Folks, in my view, this site no longer serves any useful purpose and is now closing; soon to be archived. Thank you and farewell.
Потому что штучная история.
что сдулось?
явно пользователи есть ,
давайте хвастайтесь)))))))))
NCSE = New Chassis, Special Edition
Три ноги?
Вскрыть планируете ? Это какая именно модель ncse ?
Ага. Причём отдельно от корпуса - ставь, как хочешь. Мне дилер даже дал письменные рекомендации, как ставить)
Это NCSE mk2. Фотки доступны, но в принципе могу. Этот немного модифицировали.
