А если сначала эту с SD карты
Мне прислали от Cary
The DMS-550 and DMS-600 include TIDAL, Qobuz, Spotify, and vTuner built into their firmware. The older DMS-500 and current AiOS do not include Qobuz in their firmware. However, you can still stream Qobuz in all its high-resolution glory if you are a Roon or Audirvana user. Both have Qobuz integrated into its platform and since the DMS-500 and AiOS are Roon Ready, you can stream Qobuz via Roon’s RAAT protocol or with Audirvana via DLNA. Pretty cool!
So, what about the initial question of how do I use other streaming audio services with DMS and AiOS that are not built into them? It is very simple. The DMS and AiOS also include Bluetooth and Airplay. You simply open the streaming service app in question and connect it to the DMS or AiOS with either Bluetooth or Airplay. Keep in mind Airplay is for the most part only available on iOS devices. Bluetooth is a great and easy way to enjoy CD quality or below from other services. Please know with Bluetooth the data stream comes into your phone/tablet and is transmitted straight to the DMS or AiOS. Because the signal is “point to point,” Bluetooth range is limited, and walls or obstacles can interfere. Bluetooth is usually below CD quality. If the streaming service is below CD quality (which many are), then no loss in sound quality. If you have a phone or tablet that is AptX or AptX HD Bluetooth, then you can stream CD quality or slightly better from a streaming service, if that streaming service is CD quality or better. Airplay is another way to do this. With Airplay the data stream comes into your phone/tablet and is transmitted to your network router via Wi-Fi. The router then sends the signal to the DMS or AiOS either with Wi-Fi or Ethernet cable depending on how you have the DMS or AiOS connected to your router. Airplay range is much greater (depending on your network) and higher quality. This is a better choice for streaming services offering CD quality music. Short of a high-resolution music streaming service, any service you stream to the DMS or AiOS via Airplay is basically as good as what the streaming service is offering.
There you have it! With Bluetooth and Airplay your choices for streaming audio services expand well beyond what is integrated into the DMS and AiOS platform. What’s more, you do not have to sacrifice quality beyond what the streaming services offer. Enjoy Pandora, iHeart Radio, Tunein Radio, Apple Music, Google Play Music, Amazon Music, and MUCH more.
ПЕРЕВОД
DMS-550 и DMS-600 включают в себя TIDAL, Qobuz, Spotify и vTuner, встроенные в их прошивку. Старые версии DMS-500 и текущие версии AiOS не включают Qobuz в свои прошивки. Тем не менее, вы все равно можете транслировать Qobuz во всей красе с высоким разрешением, если вы являетесь пользователем Roon или Audirvana. Оба имеют Qobuz, интегрированный в свою платформу, и, поскольку DMS-
500 и AiOS готовы к Roon, вы можете транслировать Qobuz через протокол RAAT Roon или с Audirvana через DLNA. Довольно круто!
Итак, как насчет первоначального вопроса о том, как использовать другие сервисы потокового аудио с DMS и AiOS, которые в них не встроены? Все очень просто. DMS и AiOS также включают Bluetooth и Airplay.
Вы просто открываете соответствующее приложение потоковой передачи и подключаете его к DMS или AiOS с помощью Bluetooth или Airplay. Имейте в виду, что Airplay по большей части доступен только на устройствах iOS. Bluetooth - отличный и простой способ получить качество CD или ниже от других сервисов.
Пожалуйста, знайте, что через Bluetooth поток данных поступает на ваш телефон / планшет и передается прямо в DMS или AiOS. Поскольку сигнал передается «от точки к точке», диапазон Bluetooth ограничен, и стены или препятствия могут мешать. Bluetooth обычно ниже качества компакт-дисков. Если качество потоковой передачи ниже CD (а многие из них),
тогда нет потери качества звука. Если у вас есть телефон или планшет с поддержкой AptX или AptX HD Bluetooth, вы можете передавать качество CD или немного лучше из потоковой службы, если эта потоковая служба имеет качество CD или лучше. Airplay - еще один способ сделать это.
С помощью Airplay поток данных поступает на ваш телефон / планшет и передается на ваш сетевой маршрутизатор через Wi-Fi. Затем маршрутизатор отправляет сигнал в DMS или AiOS с помощью кабеля Wi-Fi или Ethernet, в зависимости от того, как DMS или AiOS подключены к маршрутизатору. Дальность трансляции намного больше (в зависимости от вашей сети) и более высокого качества.
Это лучший выбор для потоковых сервисов, предлагающих музыку CD-качества. За исключением службы потоковой передачи музыки с высоким разрешением, любая служба, которую вы транслируете в DMS или AiOS через Airplay, в основном так же хороша, как и служба потоковой передачи.
Вот и все! Благодаря Bluetooth и Airplay ваш выбор потоковых аудиоуслуг выходит далеко за рамки того, что интегрировано в платформу DMS и AiOS. Более того, вам не нужно жертвовать качеством помимо того, что предлагают потоковые сервисы. Наслаждайтесь Pandora, iHeart Radio, Tunein Radio, Apple Music, Google Play Music, Amazon Music,
и многое другое.
Анатолий! ну и что они прислали??? Редкой души человеки!
начиная со 2-го абзаца - маркетинговые песни, причем “дешевого пошива”.
что касается встроенного Тидал - может быть с определенного номера изделия уже и устанавливается, с более поздней прошивкой соответственно!
roon - тоже в более поздних прошивках (какой qobus???).
Меня они долго распрашивали, где купил, кто дилер И так далее итп
в конечном итоге:
"Sergey
Yes, it has very old firmware. It order for it to function in must be updated to the 2.0 platform. This can only be done at our factory in the U.S.
Regards,
Daryl Berk | Sales & Product Manager
CARY AUDIO
6301 Chapel Hill Road | Raleigh, NC 27607
919-867-4333 DIRECT
813-494-8727 MOBILE
www.caryaudio.com"
присылайте на фабрику!!!
меня стошнило от такого ответа, если честно…
так лаконично меня давно никто не “посылал”
бездари!
за “кучу денег” сырые дрова продают, а потом - умничают!
что от них после этого ждать?
Я больше верю “нашим людям”!
вот и Вы - заморачиваетесь с моим вопросом, а для них сбросить 150Мб с новой прошивкой - не стоило бы ничего!
простите за эмоциональность
насчет v1.27:
все сделал - sd карта “заряжена”, находится на “низком старте”
Подожду пока, что Олег накопает/скажет.
А дальше будем пробовать 1.27, затем через интернет
Не гоже, таки, чтобы часть функционала не работала
А вообще, как Вы оцениваете работу службы поддержки CaryAudio?
Я первый раз с таким сталкиваюсь, например yamaha wxc-50 - сама предлагает обновиться, время от времени.
А вот представьте, если бы компания Apple ответила клиенту - “для установки новой версии iOS - пришлите нам свой телефон!”
Что бы прозошло в мире? Апокалипсис, как минимум!
Задаться целью - утопить их в письмах? технично засрать их компанию?
Главное вежливо и… не отказали! Приносите
Обычно службы поддержки так отвечают, если для установки требуется либо заменить какую-то деталь, возможно несовместимую с новой прошивкой.
ok, пусть будет не последняя версия прошивки, а пред или пред-предпоследняя (их там было более 10). Просматривается масса вариантов - было бы желание!
а желания - нет! вот Вам и имдж бренда!
Я лично 10 раз подумаю перед покупкой аппаратов CaryAudio, в их ценовой категории можно и повыбирать, в том числе и с более радушным отношением производителя!
“Балалайка” , просто за большие деньги, ничего в ней сверхвеликого нет!
DMS-500 это офигенно звучащая балалайка! А что нам, меломанам, ещё нужно для счастья?
Ну, сама по сбе она не играет, как минимум надо кое-что еще … а из этого кое-что источник стоит не на первом месте; более важными мне кажутся:
- исходный аудиоматериал
- помещение для прослушивания
- акустические системы
- усиление
а за 3+ килобакса можно и r2r цап взять и транспорт и на обмывку останется!
аппарат - неплох, но здесь , как в часах “Hublo” или “Nardin” - много пафоса и понтов.
Если покупать в пределах 200 тыс.,то это отличный вариант. Про ритейл речи нет вообще.
А вы у них напрямую покупали или через дилера в России? Если через дилера, то обращаться надо к дилеру. Ибо в стране, где сидит производитель, отправить аппаратуру на фабрику и отослать обратно - обычное дело. Кто ж вам виноват, что вы купили ее за океаном и теперь с пересылкой сложности.
Понятное дело, что производитель не хочет, чтобы вы по какой-то причине угробили аппарат, а потом производителю же высказали претензии.
Все что Вы пишите - абсолютно верно! До боли верно! черсчур верно!
Я называю это - отработать (поиметь) по формальному признаку!
К сожалению, мы тоже уже очень близко подошли к этой черте формализма, где процессы регламентированы, инструкции - соблюдаются И так далее…
А подумать? а вникнуть? а помочь?
Зачем?
Какова степень монетизации процесса?
Только по заявлению производителя:
TDAL
ROON
MQA
vTuner
должны работать “из коробки”
а этого - НЕТ!!! совсем!!!
пришлите нам на фабрику…
Нет, по умолчанию roon нет в 500-ом, только в 550 и 600. Он там появляется с какой-то прошивкой.
ок, а остальное?
исчезает вместе с исчезновением волшебника?
Я не помню, остальное меня не интересовало. Просто я хотел е7о купить, но увидед, что там нет руна и отказался.
Если установится рун, то tidal и qobuz у вас появятся.
Ребят,
Есть у кого опыт общения с источниками
antipodes audio ?
На самом деле - меня все устраивает! на 95%!
все очень даже неплохо!
в крайнем случае подключусь к Spotify и обойдусь без интернет-радио - есть на чем послушать!
но!!! производитель позиционирует аапарат, как не просто актуальный, а с заделом на будущее!!!
и где оно? обновление прошивки превращается в мытарство и головную боль!
ну , и кому верить?
вообще - сетевые проигрыватели вещь - “стареющая на глазах”
у меня “валяется” (стоит без дела NAD C446).да интернет-радио с него можно послушать, а вот pcm 24/192 воспроизвести не может! а стоил 7 лет назад - не 5 копеек
посему покупка раздельного ЦАПа и транспорта - считаю более рациональной покупкой (и по идее лучше звучащей)
стриммер на сегодня - это “расходник” , то есть устройство с очень коротким жизненным циклом
В России появился манюпенький стример от Triangle
https://www.salonav.com/arch/2020/10/kompaktnyj-strimer-triangle.htm
