[СНЯТО С ПРОДАЖИ] Mirage OM-5 OMNIPOLAR with powered subwoofers
Продаю, топовую, омниполярную акустику с активной НЧ секцией.
Полная комплектация, заводская упаковка.
Specification:
System Type: OMNIPOLAR™ Floor-Standing Tower; 3-Way, 6 Driver System
Subwoofer Type: Powered/Active (Internal power MOS FET amplifier: 250 Watts)
Frequency Response: 22Hz-20KHz (+/- 3dB)
Drivers / Speakers:
● Two 1" (25mm) PTH™ Pure Titanium Hybrid Tweeters In An Omnipolar Array
● Two 4.5" (115mm) Carbon-Graphite-and-Mica-filled Polypropylene Midrange Cones With Butyl Surrounds In An Omnipolar Array
● Two 8" (200mm) Polypropylene Woofer Cones With Butyl Surrounds In An Omnipolar Array - controlled by a 250-watt integrated MOS FET amplifier. The low-frequency signal is controlled by means of two knobs - the volume and frequency.
Crossover Points: 200Hz and 2 kHz; Bass Equalization System Technology
Room Sensitivity: 90 dB
Impedance: 6 Ohms Nominal / 4 Ohms Minimum
Recommended Amplifier Power: 100 to 300-watts RMS/Channel Gold-Plated, 5 way
Inputs: Bi-amp/Bi-wire Terminals
Dimensions (H x W x D ): 132.4 x 29.4 x 41.5(cm)
Finish: Cherry
Includes two power cables.
Weight: 41.8kg each
140000руб.
Город укажите пожалуйста.
г. Орёл
