4k@120Hz - 4K/2160p@120Hz supported only after a future firmware update
1440p resolution support (gamers only or for people who use tv as a monitor)
VRR with 40Hz-120Hz range (gamers only)
Nvidia G-Sync Compatible support (gamers only) for the C9 and E9 - via a future firmware update (Oct/Nov 2019)
eARC adds support for bitstreaming lossless HD audio (Dolby TrueHD, TrueHD+Atmos, DTS-HD HR, DTS-HD MA & DTS:X
HDCP 2.3 - supported only after a future firmware update
ALLM (Auto Low Latency Mode) (gamers only)
WiSA Ready - the PUA model is able to connect to a 5.1/7.1 (no Atmos for now) wireless audio system. Transmitter dongle required and sold separately. Compatibility available via firmware update later in 2019
Bluetooth – C9 has the 5.0 version (C8 has the 4.2) - all devices can be BLE (Bluetooth Low Energy), Bluetooth 5.0 allows you to play audio on two connected devices at the same time (aka Dual Audio), four times the range (240 meters), two times the speed (2 Mbps), and eight times the broadcasting message capacity of older versions of Bluetooth;
Variable Analog Audio Out (3.5mm headphone jack)
improved color volume
expanded calibration options
improved temporary image retention
screen is less darkened for news channels that have icons, banners, etc. (less aggressive ABL)
significantly improved input lag for many resolutions/refresh rates (under 7ms at 120Hz, gamers only)
metal stand instead of plastic, larger footprint, more stable
improved WebOS (version 4.5, runs smoother, plus a few more options)
Google Assistant support
Amazon Alexa support (only after May 2019 03.60.02 firmware update)
Apple AirPlay 2 and Apple HomeKit support (only after the June 2019 03.60.19 firmware update)
Connect/control various Internet of Things devices
improved motion handling
improved black crush
possibly better at avoiding burn-in, time will tell (less relevant for non-gamers and non-news watchers)
The US C9 models lack power management features that were present in the C8, but the EU C9 models do have the ECO MODE menu
Собственно, после калибровки они почти идентичные результаты показывают 9,5 и 9,6. Не знаю, на сколько это большая разница на деле, но что - то мне подсказывает, что этого даже и не увидеть
Но опять же, LG, конечно, не славится своей калибровкой с завода, но в данном тесте вполне может быть, что такой вот экземпляр попался. Так - то от одной ревизии к другой… Разное качество калибровки, мало ли
Печалька.
Кто замечал такую проблему? Я тоже это заметил в магазине, но не уверен, что дело не в настройках. Там где у lg черное пятно, у того же qled - видны всякие мелочи.
У тети та же матрица, соответственно есть шанс что проблема не аппаратная и будет пропатчена, причин может быть много, от калибровки до агрессивно задушенного ABL, надо следить в ветках, своевременно апдейтить firmware, сбрасывать на заводские и соблюдать пошаговые faq + калибровать (аппаратно естественно, не на глаз).
[16.12, 22:25] Петр: Неужели только я вижу, даже на этих фото, с самыми разными настройками одни и те же недостатки - олед на черном тупо пятно, у ips видно структуру. Цветов больше у ips, цвета естественнее. На последних фото у мальчика майка с полосками - у олед явно меньше цветов и где тень на майке вообще ничего не видно. И это при том, что яркость этот тип специально вытягивал, имея оборудование жля калибровки
[16.12, 22:28] Петр: Функция Automatic Brightness Limiter (ABL) : Телевизоры LG - Помощь
Да вот сидишь и думаешь, смотреть на бандинг, возможно, чёрный без градации или нерпвеомерные засветы, размазанные по всей панели, при чем в любом ценовом сегменте
Мне, вообще, в моем сценариии использования нужно всего лишь, казалось бы, чуть - чуть: 55 панель, норм проц и программная обработка, что бы смотреть 720р, 1080р рипы и ремуксы, отсутствие шим или высокочастотный, как у LG, в полумраке, в темноте не видеть белых сюрреалистических картин, приличная яркость в sdr, сильно не бликовал, может быть, не так уж и мало получилось, но хрен найдёшь, даже в 100-ню ± со всем этим набором достоинств. 4K совсем не нужен, в 55 диагонали мне, так ведь тренд, блин, который уже сменился, как я понял намаливанием на пиковую яркость в hdr, теперь из этого маркетологи выжимают
PS: хотя после моего Samsung 7 летней давности, далеко не топового даже на то время, я думаю, что я любой возьму и скажу: “****, **** и ****”. Просто хочется взять что - то прям годное, а тут просто ярмарка компромисов, без нужного набора, так, пожалуй, всегда было И эта сволочь до сих пор же работает, этот Samsung, не даёт принимать координальных мер с покупкой, кое - где олеофообка чуть - чуть слезла, если подходить к выключенному и присматриваться))
Да, я понял о чем речь. Ну, как Юрий написал, возможно там собака зарыта, я про магазины дополнил в контексте того, что там безбожный режим во всех отношениях для “ути-пути” нежной oled матрицы
