Твердотельный транспорт аудиофайлов BBP101 Plus 24 bit 192kHz
Транспорт аудиофайлов BBP101 Plus 24 bit 192kHz (Digital transport - SD card WAV Audio Player) поддерживает только WAV формат разрядностью 192k/24bit, 176.4k/24bit, 96k/24bit, 88.2k/24bit, 48k/24bit и 44.1k/16bit. Носитель - 32G SDHC SD card. Два 1ppm low jitter 22.5792 and 24.576Mhz TCXO. Имеет три выхода: Spdif RCA, Spdif BNC (precision 75Ohm socket), I2S output (mini AES socket). Питание 220 в. ПДУ, дублирующий функции кнопок управления на передней панели, а также позволяющий отключать подсветку дисплея, в комплекте.
Описание производителя:
a. Decompress audio file basically is not a time constant tasking, time latency will vary for different data context. It will be too difficult to get low jitter operation.
b. Decompressing will need micro processor and software operation. Low jitter performance will not possible unless complex OS and digital stream buffer design deployed. While it will be a quite high cost design but still fail to get very good performance.
c. Users can readily convert all music file format to WAV format in minutes and storage it for later usage. So we think sole WAV file format support may not be a problem.
Extremely low jitter performance
High speed FPGA based hardware implement for file access, file data extract, signal procession and Spdif signal composition.
No software based operation for audio procession. This design ensure most low jitter appear in circuit.
Precision 75Ohm BNC socket for Spdif output.
High Grade electric parts usage
All parts used in this player are carefully chosen for best performance. No cost down consideration.
You can take this player to compete best CD transport or digital media player on market.
You will agree this is a very very high performance digital signal source for critical audiophiles.
Подробную информацию о девайсе легко найти в сети, например, здесь: BBP 101 Plus 24bit 192k Digital Transport » Аудиоаппаратура » Аудио » Форум oStereo.ru
От себя добавлю: единственный файловый плеер из тех, что у меня были или есть (Pioneer N-50к, Aune S1, Soundaware D100, Shinrico D7 и еще какие-то изделия кулибиных на базе персональных компьютеров под Windows), обеспечивающий качество цифрового сигнала на уровне весьма дорогих специализированных СД-транспортов (Accuphase DP80).
Цена - 8999 рублей. Находится в Москве. Учитывая, что сделан надежно, как танк, а вес и габариты позволяют, могу переслать Почтой России при условии оплаты расходов по пересылке.
Евгений. Тел.: 8(495) 470-50-70 или [email protected]
Редкая и уникальная вещь для аудиопуристов, готовых пожертвовать универсальностью ради бескомпромиссного звука.
Цена – 7999 рублей.
Предновогодняя цена - 7499 рублей.
Продан.
