Π³Π»ΡΠ½Ρ ΡΡΠΎ Π½Π° ΠΌΠΎΠ΅ΠΉ RTA ΠΏΠΎΠΊΠ°ΠΆΠ΅Ρ.
Π’Π°ΠΌ ΠΌΠ΅ΡΡΠ°ΠΌΠΈ ΠΎΠΊΠΎΠ»ΠΎ 10 Π³Π΅ΡΡ. ΠΠ΅ΠΊΠΎΡΠΎΡΡΠ΅ Π°ΡΠ΄ΠΈΠΎΡΠΈΠ»Ρ ΠΈΠΌ Π΄ΠΈΠ½Π°ΠΌΠΈΠΊΠΈ ΡΠ°Π·ΠΌΠΈΠ½Π°ΡΡ Π£ ΡΠ΅Π±Ρ Π΄ΠΎΠ»ΠΆΠ½ΠΎ ΠΎΡΡΠ΅Π·Π°ΡΡΡΡ.
ΠΠΎΡΠΎΠΌ Π²Π°Π²ΠΊΡ Π³Π»ΡΠ½Ρ.
Π·Ρ: ΠΊΡΠ°ΠΉΠ½Π΅ ΡΠ²ΠΎΠ΅ΠΎΠ±ΡΠ°Π·Π½ΠΎ ΠΎΡΠΊΡΡΠ²Π°ΡΡΡΡ (Π΄Π»ΠΈΠ½Π½ΡΠ΅) Π²Π°Π²ΠΊΠΈ Π² ΡΠ΅Π²ΠΎΠ²ΡΠΊΠΎΠΌ Π Π’Π
Π§ΡΠΎ-ΡΠΎ ΠΏΡΠΎΡΠΊΠ°ΠΊΠΈΠ²Π°Π΅Ρ ΠΏΠΎΡΠ»Π΅ ΡΠΈΠ»ΡΡΡΠ°. Π‘ΠΈΠ½ΠΈΠΉ - ΡΡΠΌ ΠΊΠΎΠΌΠ½Π°ΡΡ
ΠΠ° ΠΈ Π²ΠΎΡΠΏΡΠΎΠΈΠ·Π²Π΅ΡΡΠΈ ΠΌΠΎΡ Π°ΠΊΡΡΡΠΈΠΊΠ° ΡΠ°ΠΊΠΎΠ΅ Π½Π΅ ΡΠΌΠΎΠΆΠ΅Ρ.
ΠΠΎΠ½ Π²ΠΈΠ΄Π½ΠΎ, ΠΊΠ°ΠΊ ΡΠΏΠ΅ΠΊΡΡ ΠΊΠ²Π°Π΄ΡΠ°ΡΠ° ΡΠΎΡΡΠΎΠΈΡ ΠΈΠ· Π½Π΅ΡΠ΅ΡΠ½ΡΡ
Π³Π°ΡΠΌΠΎΠ½ΠΈΠΊ. Π‘ΠΏΠ΅ΠΊΡΡ ΡΡΠ΅ΡΠ³ΠΎΠ»ΡΠ½ΠΈΠΊΠ° ΠΈΠ· ΡΠ΅ΡΠ½ΡΡ
, Π° ΡΠΏΠ΅ΠΊΡΡ ΠΏΠΈΠ»Ρ - ΠΈΠ· Π²ΡΠ΅Ρ
. ΠΠΎΠΆΠ½ΠΎ ΠΈ ΠΏΠΎΡΠ»ΡΡΠ°ΡΡ ΡΡΠΎ Π·Π°ΠΎΠ΄Π½ΠΎ.
ΠΠ° ΡΡΡΡΠΊΠΎΠΌ Π€ΠΎΡΠΌΡ Π²ΠΎΠ»Π½Ρ | Digital Music Academy
Π‘ΠΏΠ΅ΠΊΡΡ ΡΠΎΠ·ΠΎΠ²ΠΎΠ³ΠΎ ΡΡΠΌΠ° ΡΠΎΠΎΡΠ²Π΅ΡΡΡΠ²ΡΠ΅Ρ Π°ΡΡ Π΅. Π Π΄ΡΠ΅Π²Π½ΠΎΡΡΠΈ ΡΠΏΠ΅ΠΊΡΡΠΎΠ°Π½Π°Π»ΠΈΠ·Π°ΡΠΎΡΠ°ΠΌΠΈ Ρ ΡΠΎΠ·ΠΎΠ²ΡΠΌ ΡΡΠΌΠΎΠΌ ΠΈ ΠΏΠΎΠ»ΡΠ·ΠΎΠ²Π°Π»ΠΈΡΡ Π΄Π»Ρ Β«ΠΈΠ·ΠΌΠ΅ΡΠ΅Π½ΠΈΡ Π°ΡΡ ΠΈΒ», Π΄Π° ΠΈ ΡΠ΅ΠΉΡΠ°Ρ ΠΈΠ½ΠΎΠ³Π΄Π°.
Π Π²ΠΎΡ ΠΈ ΠΈΠ½ΡΠ΅ΡΠ΅ΡΠ½Π°Ρ ΠΏΠ»Π°ΡΠΊΠ° ΠΎΠ±Π½Π°ΡΡΠΆΠΈΠ»Π°ΡΡ (Π²ΡΠΏΡΡΡΠΈΠ»ΠΈ). Π’Π΅ΠΏΠ΅ΡΡ Π½Π΅ ΠΎΠ±ΡΠ·Π°ΡΠ΅Π»ΡΠ½ΠΎ ΡΠ°Π·ΠΎΡΡΡΡΡΡ Π½Π° Π΄ΠΎΡΠΎΠ³ΠΎΠΉ DAC Π½Π° 8 ΠΊΠ°Π½Π°Π»ΠΎΠ²
- 8 channel sound output
- Four dedicated 192kHz/24bit high-quality Burr-Brown DACs
- Connects directly to the Raspberry Pi, no additional cables needed
- No soldering, comes as a pre-fabricated kit. You just plug it onto the Raspberry Pi
- Compatible with all Raspberry Pi 5
- Directly powered from the Raspberry Pi, no additional power supply
- Two ultra-low-noise linear voltage regulators for optimal audio performance
- HAT compliant, EEPROM for automatic configuration
- Comes with all components required to mount it. We include 4 M2.5x12mm spacers to fix the board onto the Raspberry Pi
SPECIFICATIONS
Maximum output voltage | 2.1Vrms | |
DAC signal-to-noise ratio | 112db | typical |
DAC THD+N | -93db | typical |
Frequency response | 10Hz-70kHz | -3dB |
Power consumption | <0.3W | |
Sample rates | 44.1-192kHz |
Π¦Π΅Π½Π° ~60$ Π±Π΅Π· ΡΡΠ΅ΡΠ° Π΄ΠΎΡΡΠ°Π²ΠΊΠΈ.
ΠΠ° ΠΌΠ°Π»ΠΈΠ½Ρ Camilla ΠΈβ¦
ΠΠΎΡ ΠΎΠΆΠ΅ Π½Π° ΠΏΡΠΈΠ»ΠΎΠΆΠ΅Π½ΠΈΠ΅ Π΄Π»Ρ dbx DriveRack PA2 (ΡΠΈΡΡΠΎΠ²ΠΎΠΉ ΠΊΡΠΎΡΡΠΎΠ²Π΅Ρ + DSP):
Π‘ΡΠ°Π»ΠΊΠ΅Ρ ΠΊΡΠ°ΡΠΈΠ²ΠΎΠ΅ ΠΏΠΎΠΊΠ°Π·ΡΠ²Π°Π» ΠΏΡΠΈ ΡΠ²Π΅Π΄Π΅Π½ΠΈΠΈ ))
ΠΠΎΠΏΡΠΎΠ±ΡΠ΅ΠΌ ΡΠ°ΠΊΠΎΠ΅β¦
ΠΡΠ³Π»ΡΠ΄ΠΈΡ ΠΏΠΎΠΊΠ° ΡΡΡΠ°ΡΠ½ΠΎ, Π½ΠΎ Π΅ΡΠ»ΠΈ ΡΠ΅Π·ΡΠ»ΡΡΠ°Ρ ΠΏΠΎΠ»ΡΡΠΈΡΡΡ ΠΊΡΠ°ΡΠΈΠ²ΡΠΉ, ΡΠΎ ΠΎΡΠΎΡΠΌΠ»Ρ ΠΏΠΎ Π²ΡΡΡΠ΅ΠΌΡ ΠΊΠ»Π°ΡΡΡ
Π‘ΠΎΠ±ΡΠ°Π» ΠΈ Π·Π°ΠΏΡΡΡΠΈΠ» ΠΏΡΠΎΠ΅ΠΊΡ. ΠΠΎΠΊΠ° Π²ΡΠ³Π»ΡΠ΄ΠΈΡ ΡΡΡΠ°ΡΠ½ΠΎ, Π½ΠΎ Π²Π½ΡΡΡΠΈ Π³ΠΈΠ±ΠΊΠΎΡΡΡ ΠΈ ΠΊΡΠ°ΡΠΎΡΠ° Π² ΠΌΠ΅Π³Π°ΠΎΠ±ΡΡΠΌΠΈΡΠ΅
ΠΡΡΡΠΈΡΡ ΠΈ Π²Π΅ΡΡΠ΅ΡΡ ΠΌΠΎΠΆΠ½ΠΎ Π΄ΠΎ Π±Π΅ΡΠΊΠΎΠ½Π΅ΡΠ½ΠΎΡΡΠΈ ΠΈ Π°Π±ΡΠΎΠ»ΡΡΠ½ΠΎ Π²ΡΡ. ΠΡ Π° Π΅ΡΠ»ΠΈ Π½Π΅ Π±ΡΠ΄Π΅Ρ Ρ
Π²Π°ΡΠ°ΡΡ ΠΌΠΎΡΠ΅ΠΉ (Ρ
ΠΎΡΡ Π½Π΅ ΠΏΠΎΠΊΠ° Π½Π΅ ΠΏΡΠ΅Π΄ΡΡΠ°Π²Π»ΡΡ ΡΠ°ΠΊΠΎΠ³ΠΎ), ΡΠΎ ΠΌΠΎΠΆΠ½ΠΎ Π½Π° ΠΊΠ°ΠΆΠ΄ΡΠΉ ΠΊΠ°Π½Π°Π» ΠΏΠΎ ΡΠ°ΠΊΠΎΠΉ ΠΏΠ»Π°ΡΠΊΠ΅ ΠΈΠ»ΠΈ Π½Π° ΠΊΠ°ΠΆΠ΄ΡΡ ΠΏΠΎΠ»ΠΎΡΡ
ΠΠΎΠΏΡΠΎΠ±ΡΡ Π½Π° ΠΊΠΎΠΌΠΏΡΡΡΠ΅ΡΠ½ΠΎΠΌ ΡΠ΅ΡΠ°ΠΏΠ΅ ΠΈ Π·Π°ΡΠ΅ΠΌ ΠΏΠ΅ΡΠ΅Π½Π΅ΡΡ Π² ΠΎΡΠ½ΠΎΠ²Π½ΠΎΠΉ. ΠΠ° Π΅ΡΡ ΠΈ Ρ ΠΠΈΡΠ°ΠΊ ΡΡΠΎΠ»ΠΊΠ½Ρ
Π Π΅Π·ΡΠ»ΡΡΠ°ΡΠ°ΠΌΠΈ (Π·Π°ΠΌΠ΅ΡΠ°ΠΌΠΈ ΠΈ Π²ΠΏΠ΅ΡΠ°ΡΠ»Π΅Π½ΠΈΡΠΌΠΈ) ΠΏΠΎΠ΄Π΅Π»ΡΡΡ.
ΠΡΠ΅ Π½ΠΈΠΊΠ°ΠΊ Π½Π΅ Π΄ΠΎΠ±Π΅ΡΡΡΡ Π΄ΠΎ Roon, Π½ΠΎ ΠΎΡΡΠ°Π²Π»Ρ ΡΡΠΎ Π·Π΄Π΅ΡΡ:
dirac Π½Π°ΠΌΠ΅ΡΠΈΠ» ΠΊΠΎΠ½Π΅ΡΠ½ΠΎ ΠΌΠ½Π΅, ΡΠΆΠ°Ρ ΡΠΆΠ°Ρ Π΄ΠΎ 200 ΠΡ
ΠΊΠ°ΠΊ ΠΏΠΎΠ»Π°Π³Π°Π΅ΡΠ΅, Π΄ΠΎ 600 ΠΡ Π΄ΠΎΡΡΠ°ΡΠΎΡΠ½ΠΎ ΠΎΡΡΠ°Π²ΠΈΡΡ?
Π²ΡΡΠ΅ ΡΠΆΠ΅ Π±ΠΎΠ»Π΅Π΅ ΠΌΠ΅Π½Π΅Π΅ ΠΈ Π±Π΅Π· ΠΊΠΎΡΡΠ΅ΠΊΡΠΈΠΈ
Π½Π΅ ΡΠΆΠΎΡ, ΠΎΠ±ΡΡΠ½ΠΎΠ΅ Π΄Π΅Π»ΠΎ Π² ΠΎΠ±ΡΡΠ½ΠΎΠΉ ΠΊΠΎΠΌΠ½Π°ΡΠ΅.
Π― Π±Ρ Π²ΠΎΠΎΠ±ΡΠ΅ ΠΊΠΎΡΡΠ΅ΠΊΡΠΈΡ ΡΠΎΠ»ΡΠΊΠΎ Π΄ΠΎ 200-300ΠΡ ΠΏΡΡΠΊΠ°Π», ΠΈ Π² Π‘Π§ Π΄ΠΈΠ°ΠΏΠ°Π·ΠΎΠ½ Π½Π΅ Π»Π΅Π·.)))
Π΄Π°, ΠΏΠΎΠΆΠ°Π»ΡΠΉ ΡΠΎΠΆΠ΅ Π²Π°ΡΠΈΠ°Π½Ρ
Π³ΠΎΡΠ± Π½Π° 150-200 ΠΡ ΡΠ±ΡΠ°ΡΡ ΡΠΎΠ»ΡΠΊΠΎ
Π·Π°Π²ΡΡΠ° ΠΏΠΎΠΏΡΠΎΠ±ΡΡ)
Π½Π° Π°ΡΡΠ΅ ΡΠΏΠ΅ΡΠΈΠ°Π»ΡΠ½Π°Ρ Π²Π΅ΡΠΊΠ° ΠΏΡΠΎ Π΄ΠΎΠΊΡΠ΄Π° ΠΊΠΎΡΡΠ΅ΠΊΡΠΈΡΠΎΠ²Π°ΡΡ; Π²ΡΠΎΠ΄Π΅ ΡΠ°ΠΊ ΠΈ Π½Π΅ ΠΏΡΠΈΡΠ»ΠΈ ΠΊ ΠΊΠΎΠ½ΡΠ΅Π½ΡΡΡΡ
ΠΠ°, ΠΎΠ±ΡΡΠ½Π°Ρ ΡΠ΅ΠΌΠ°. Π£ Π²ΡΠ΅Ρ
ΡΠ°ΠΊ ΠΏΠ»ΡΡ/ΠΌΠΈΠ½ΡΡ, ΠΏΡΠΎΡΡΠΎ Π½Π΅ Π²ΡΠ΅ ΠΈΠ·ΠΌΠ΅ΡΡΠ»ΠΈ )
ΠΠΎ ΡΡΠ½ΡΡΡ Π΄ΠΎ 300. ΠΠΎ Π½ΠΈΠΊΡΠΎ Π½Π΅ ΠΌΠ΅ΡΠ°Π΅Ρ ΠΏΠΎΠ»Π½ΡΡ ΠΏΡΠΎΠ²Π΅ΡΡΠΈ ΠΈ ΠΏΠΎΡΠ»ΡΡΠ°ΡΡ, ΡΡΠ°Π²Π½ΠΈΡΡ.
ΠΠ΄ΡΡΠ³ ΠΏΠΎΠ½ΡΠ°Π²ΠΈΡΡΡ.
ΠΠΎ ΠΌΠ½Π΅ ΡΠ°ΠΊ Π²ΡΡΠ΅ 10 ΠΊΠΡ ΠΏΠ°ΡΡ Π΄Π Π½Π°ΠΊΠΈΠ½ΡΡΡ Π΄Π»Ρ ΠΈΡΠΊΠΎΡΠΊΠΈ.
ΠΠ°, Ρ Π΄Π»Ρ ΡΠ΅Π±Ρ ΠΏΠΎΠ½ΡΠ», ΠΊΠΎΠ³Π΄Π° Π΅ΡΡ ΠΏΡΠΎΠ±ΠΎΠ²Π°Π» Π°ΠΏΠΏΠ°ΡΠ°ΡΠ½ΡΡ ΠΊΠΎΡΡΠ΅ΠΊΡΠΈΡ, ΡΡΠΎ Π½Π° Π½Π΅ΠΊΠΎΡΠΎΡΡΡ ΠΊΠΎΠΌΠΏΠΎΠ·ΠΈΡΠΈΡΡ ΠΎΡΡΡΡΠ»ΠΈΠ²ΠΎ ΡΠ»ΡΡΡ ΠΎΡ 200 Π½Π° Π½Π΅ΠΊΠΎΡΠΎΡΡΡ Π²ΠΎΠΎΠ±ΡΠ΅ ΡΠ°Π·Π½ΠΈΡΡ Π½Π΅ ΠΏΠΎΠ½ΠΈΠΌΠ°Ρ. Π’Π°ΠΊ ΡΡΠΎ ΠΎΡΡΠ°Π½ΠΎΠ²ΠΈΠ»ΡΡ Π½Π° ΠΎΡ 200 ΠΏΡΠΈ ΠΌΠΈΠ½ΠΈΠΌΠ°Π»ΡΠ½ΠΎΠΉ ΠΎΠ±ΡΠ°Π±ΠΎΡΠΊΠ΅ ΠΏΠΎΠΌΠ΅ΡΠ΅Π½ΠΈΡ.)))
ΠΠ° Π½Π΅Π΅β¦ ΡΡΠ°Π½Π΄Π°ΡΡΠ½Π°Ρ ΠΆβ¦Π° Π΄Π»Ρ Π½Π°ΡΠΈΡ ΠΊΠ²Π°ΡΡΠΈΡΠΎΠΊ: ΠΏΡΠΎΠ²Π°Π»Π΅Π½Π½Π°Ρ Π½ΠΈΠΆΠ½ΡΡ ΡΠ΅ΡΠ΅Π΄ΠΈΠ½Π°, ΠΈ Π³ΠΎΡΠΊΠΈ Π½Π° ΠΌΠΈΠ΄Π±Π°ΡΡ ΠΈ Π±Π°ΡΡ)))))
