ЦАПы с R-2R лестницей в NOS небо
В октябре.
R2R ЦАПики
47 Labs
Model 4733 Midnight Blue | PCM2707 | USB, RCA | DAC/Preamp/HPA. | $ 2,000
Model 4705 Gemini | CS8412 IS | RCA | Dual-mono. Filterless. Separate psu | $ 4,500
Abbas Esoteric Audio
DAC 0.1 | TDA1543 | RCA | NOS, tube stage | $ 378
DAC 0.1 SE | TDA1543 | RCA | NOS, tube stage | $ 698
DAC 1.0 SE | PCM56P-K | RCA | NOS, OTL tube stage, tube clock | $ 1,448
DAC 1.0 SE 6080 | PCM56P-K | RCA | NOS, OTL tube stage, tube clock, HP out, adjustable LO | $ 2,198
DAC 2.0 | TDA1541A | RCA | NOS, SE Class A stage | $ 798
DAC 2.0 SE | TDA1541R1 | RCA (x2) | NOS, OTL tube stage, 6V RMS | $ 2,448
DAC 2.1 SE | TDA1541R1 | RCA | NOS, tube stage, | $ 1,948
DAC 3.0 SE | TDA1541AS1 | RCA (x2) | NOS, tube stage, tube clock | $ unknown
DAC 3.1 | ? | ? | ? | $ unknown
DAC 4,0 | PCM58 | Coax (x2) | RCA (x2) | ? | $ 4,900
Abbingdon Music Research
AMR DP-777 | UDA1305AT/WM8742? | USB, XLR, BNC, RCA+Toslink | Dual-DAC. Selectable filtering. Tube output stage | $ 5,000
Ack! Industries
dAck! 2.0 | TDA1545A | BNC | Battery power. Filterless | $ 795
Acoustic Plan
DigiMaster | PCM1704U-K | USB, BNC, I2S | Analogue filtering. Tube output stage | $ 4,750
Aqua - Acoustic Quality
La Voce S2 | PCM1704-K/TDA1541A/AD1865 | USB, BNC, AES/EBU, I2S | Modular design | € 2,340
La Scala MKII | PCM -1704K | USB, BNC, RCA, AES/EBU, I2S | Dual-mono. Tube hybrid output stage | € 4,890
Formula | R2R + FPGA | I2S, BNC, USB, Optional (AES/EBU, RCA, AT&T, Toslink) | € 13,100
Aries Cerat
Kassandra 2 REF | AD1865N-K | USB, RCA x2, Toslink | 16 ICs per ch, tube output stage VC + Bal Out optional | € 18,000
Kassandra 2 SIG | AD1865N-K I USB, RCA x2, Toslink | 2o ICs per ch, tube output stage, separate psu, VC + Bal Out optional | € unknown
Kassandra 2 SIG LE | AD1865N-K | USB, RCA x2, Toslink | 24 ICs per ch, tube output stage, separate psu, VC + Bal Out optional | € 82,000
Arkhipov’s Laboratory
DAC63 | PCM63P | USB, RCA, Toslink | NOS, tube output stage, separate PS optional | $ unknown
DAC1541 | TDA1541A | USB, RCA, Toslink | NOS, tube output stage, separate PS optional | $ unknown
DAC1702 | PCM1702 | USB, RCA, Toslink | NOS, tube output stage | $ unknown
DAC1861 | AD1861 | USB, RCA, Toslink | NOS, tube output stage | $ unknown
DAC56 | PCM56 | RCA | NOS | $ unknown
Audial
Model S MkII | TDA1541A | BNC, I2S | € 1,950
Model S USB | TDA1541A | USB | € 1,950
Audio-gd
Master 7/NOS 7 | PCM1704UK | USB, BNC, RCA, Toslink, AES/EBU, I2S | Fully balanced | $ 2,250/2,335
Master 11/NOS 11 | PCM1704UK | USB, BNC, RCA, Toslink, I2S | DAC/Preamp/HPA. Fully balanced | $ 1,950/2,048
DAC 19/NOS 19 | PCM1704UK | USB, BNC, RCA, Toslink | $ 800/880
Singularity 19 | R2R | USB, BNC/RCA, Optical, I2S | FPGA | $ 600
R2R 7/7HE | R2R | USB, BNC, RCA, Toslink, AES/EBU, I2S | FGPA, Fully balanced | $ 2,480/3,480
R2R 11(15) | R2R | USB, RCA, Toslink | NOS, DAC/PRE/HPA | $ 350 (R2R 15 is possibly an european version of R2R 11)
ANK Audiokits (Kit or factory assembled)
DAC 2.1 | AD1865N | RCA, USB optional | Filterless | $ 1,650
DAC 3.1 | AD1865N | RCA, USB optional | Filterless. Balanced output optional | $ 2,175
DAC 4.1 C-Core | AD1865N | RCA, USB optional | Filterless | $ 3,100
DAC 5.1 Signature | AD1865NK | RCA, AES/EBU, USB optional | $ 5,500
Audio Note
DAC 0.1x, DAC 1.1x, DAC 2.1x (Signature), DAC 3.1x/II Balanced, DAC 4.1x (Signature), DAC 5 (Signature) | ?
BorderPatrol
DAC S/SE | TDA1543 | USB and/or RCA | NOS | $ 995-1,850
Computer Audio Design
CAD 1543 MKII DAC | TDA1543/N2 | USB | Filterless | £ 7,250
dB Audio Labs
Tranquility DAC | TDA1543 | USB | Filterless | $ 1,495
Tranquility DAC SE | TDA1543 | USB | $ 2,395
DDDAC
DDDAC1794 NOS Kit | PCM1794A | ?
DDCAC1543 NOS Kit | TDA1543 | ?
Denafrips
Ares | R2R | USB, RCA, Toslink | 20bit R2R+6bit DSD | $ 600
Pontus | R2R | USB, RCA, BNC, Toslink, I2S, AES/EBU | NOS/OS, 24bit R2R+6bit DSD | $ 1,480
Venus | R2R | USB, BNC, RCA, Toslink, AES/EBU, I2S | NOS/OS, 26bit R2R+6bit DSD, fully balanced | $ 2,680
Terminator | R2R | USB, BNC, RCA, Toslink, AES/EBU, I2S | 26bit R2R+6bit DSD, fully balanced | $ 3,980
DIXO Audio
USB R-2R DAC | LTC2753 | USB | DAC+HPA | € 450
EC designs
Mosaic UV | Passive resistor matrix (3VL, not regular R2R) | USB | UAC1 only (max 96 kHz), Headphone buffer, Passive VC | € 1,350
Etalon Sound
DreamDAC | R2R | USB, RCA, Toslink (x2), XLR, I2S | Fully balanced | € 14,000
HOLO Audio
Spring DAC - Level 1 “Base Model” | R2R | USB, RCA, BNC, AES, Toslink, I2S (HDMI) | NOS/OS, DSD | $ 1,600
Spring DAC - Level 2 “Rise Ji Edition” | R2R | USB, RCA, BNC, AES, Toslink, I2S (HDMI) | NOS/OS, DSD | $ 1,900
Spring DAC - Level 3 “Kitsune Tuned Edition” | R2R | USB, RCA, BNC, AES, Toslink, I2S (HDMI) | NOS/OS, DSD | $ 2,500
Junilabs
Jundac Two | PCM 1704 | BNC, RCA | € 3,200
Lab12
Lab12 DAC1 SE | TDA1543 | USB, RCA,Toslink optional | Tube output stage | $1 ,800
LessLoss
Echo’s End | R2R | USB, RCA, BNC, AES/EBU | $ 5,342
Light Harmonic
Da Vinci DAC MKII | ? | USB, RCA, AES/EBU | Dual-DAC | $ 20,000
LiTe Audio
DAC-AH | TDA1543 | RCA, Toslink | $ 138
DAC-60 | PCM1704 | RCA, Toslink | Tube output stage | $ 650
DAC-83 | PCM1704K | RCA, Toslink, AES/EBU, I2S | Fully balanced | $1,500
Metrum Acoustics
Amethyst | R2R ladder module | USB, RCA, Toslink | NOS, FPGA/DSP, DAC/HPA | €1295
Onyx | Details yet to be announced
Jade | Details yet to be announced
Pavane (Level 1/2/3) | R2R ladder module | USB, BNC, RCA, Toslink, AES/EBU | FPGA/DSP | € 4,950 / 5,750 / 6,250
Adagio | R2R ladder module | AES/EBU, BNC, RCA, USB, Toslink | NOS, FPGA, Volume Control | € 6,950
MHDT Laboratory
Canary | TDA1545A | USB, S/PDIF | NOS | $ 700
Atlantis | AD1862N-J | USB, BNC, RCA, Toslink | $ 816
Stockholm v.2 | PCM56P-J | USB, BNC, RCA, Toslink | $ 940
Orchid | TDA1541A | USB, BNC, RCA, Toslink | $ 1045
Pagoda | PCM1704 | USB, BNC, RCA, Toslink | $ 1,250
Mojo Audio
Mystique v3 DAC Single-Ended | AD1862 | USB, RCA, Toslink | $ 5000
Mystique v3 DAC Balanced | AD1862 | USB, RCA, Toslink | $ 7000
Muse Audio
Mini TDA1543x4 DAC | TDA1543 | RCA, Toslink | $ 50
Myst
PortaDAC 1704 | PCM1704 | USB, Mini-Jack, Toslink, HDMI | AC or battery pwr | ?
PortaDAC 1862 | AD1862 | USB, Mini-Jack, Toslink, HDMI | AC or battery pwr | $ 990
PortaDAC 1866OCUB v.3 | AD1866 | USB, Mini-Jack, Toslink, BT | DAC/HPA. USB or battery pwr | $ 600
DAC 1866OCU V.2 | AD1866 | USB, RCA, Toslink | DAC/HPA | $ 990
DAC 1851OCU | AD1851 | USB, RCA, Toslink | DAC/HPA | $ ?
Phasure
NOS1 | PCM1704U-K | USB | Needs XXHighEnd software player | € 5,200
Pro-Ject Audio Systems
DAC Box S FL | TDA 1543T | RCA, Toslink | € 200
RATOC Audio Lab
RAL-24192DM1 | PCM1704 | USB, RCA | DAC/HPA | € 3,000
ROCKNA Audio
Wavedream Edition | R2R | USB, RCA, AES/EBU, I2S | 26-bit ladder module | € 5,900 (SE) / 7,900 (BAL)
Wavedream Signature | R2R | USB, RCA, AES/EBU, I2S | 27-bit ladder module | € 10,900 (SE) / 14,600 (BAL)
S.A. Lab
Lilt | R2R | USB, RCA | DAC/Preamp | € 6,000
Schiit Audio
Modi Multibit | AD5547 | USB, RCA, Toslink | $ 249
Bifrost Multibit | AD5547CRUZ | USB, RCA, Toslink | $ 600
Gungnir Multibit | AD5781BRUZ | USB, BNC, RCA, Toslink | $ 1,250
Yggdrasil | AD5791BRUZ | USB, BNC, RCA, Toslink, AES/EBU | $ 2,300
Soekris Engineering
DAC1101 | R2R | USB | DAC/HPA | € 363
DAC1321 | R2R | USB, RCA, Toslink | DSD | € 460
DAC1421 | R2R | USB, RCA, Toslink | DAC/HPA, DSD | € 735
DAC1541 | R2R | USB, RCA, BNC, Toslink, AES | Fully balanced DAC/HPA, DSD | € 1100
Starting-Point Systems
Mini TDA1543 Battery DAC | TDA1543 | RCA, Toslink | Battery power | $ 235
DAC 3 | TDA1543 | USB, RCA, Toslink | Battery power | $ 465
SW1X Audio Design — это же перемаркировка Аббасс ЦАПов
DAC 1 | TDA1543 | RCA | NOS, passive I/V, tube output stage | £ 1,050
DAC 1 STD | TDA1543 | RCA | NOS, active I/V, tube output stage | £ 1,150
DAC 1 Special | TDA154 | RCA | NOS, active I/V, tube output stage + PSU | £ 2,000
DAC 1 Special X | TDA154 | USB, RCA | NOS, active I/V, tube output stage + PSU | £2500
DAC 1 Signature | TDA1543 | RCA | NOS, active I/V, tube output stage | £ 1,650
DAC 2 STD | PCM56-K | RCA | NOS, active I/V, tube output stage | £ 2,500
DAC 2 Special | PCM56-K | ? | ? | £ 3,500
DAC 2 Signature | PCM56-K | RCA | NOS, active I/V, tube output stage | £ 4,200
DAC 3 STD | TDA1541 | RCA | NOS, active I/V, tube output stage | £ 4,400
DAC 3 Special | TDA1541 | ? | ? | £ 5,500
DAC 3 Balanced | TDA1541 | RCA, XLR | NOS, active I/V, tube output stage | £ 7,000
DAC 3 Signature | TDA1541 | RCA, XLR | NOS, active I/V, tube output stage | £ 10,000
DAC 4 | to be announced
Tento Engineering
Porta DAC2 | AD1866 | USB, RCA, Toslink, BT | DAC/HPA. Battery pwr. AptX | € 600
TeraDak Audio Electric Company
TDA1543 NOS DAC-V3.1D | TDA1543 | USB, RCA, Toslink | $ 270
TDA1543 NOS DAC-V4.1D | TDA1543 | USB, RCA, Toslink | Separate. psu | $ 290
TDA1543 NOS DAC-V4.5 | TDA1543 | USB, RCA, Toslink | Separate. psu | $ 425
Thrax Audio
Maximus | R2R | RCA, AES/EBU, Toslink, USB optional | $ 33,000
Totaldac
d1-six (server/streamer) | € 13,500 (14,500)
d1-dual DAC | Fully balanced | € 9,900
d1-tube-mk2 DAC | Fully balanced. Tube output stage | € 9,900
d1-single-mk2 DAC | 6,960
d1-twelve DAC (server) | 3 box system | € 28,500 (29,500)
d1-integral-headphone server/DAC | € 8,400
Veridian Utopia
Excellence DAC | AD1865 | USB, RCA, Toslink, AES | NOS, tube buffer, Preamp, customizable | $ ?
Sirius DAC | AD1865 |USB, RCA, Toslink, AES + one additional input | NOS, tube buffer, fully balanced | $ ?
Wavelength Audio
Brick USB DAC v2 | TDA1543N2 | USB | $ 1,750
Cosecant HS (Transcendental) | TDA1543N2 | USB | Filterless | $ 3,500
Crimson HS (Transcendental) | TDA1543N2 | USB | Tube output stage. Filterless | $ 7,500
Ypsilon Electronics
DAC 100 | PCM1704K | RCA | $ 29,000
Zanden Audio
Model 5000 Signature | TDA1541A | BNC, RCA, AES/EBU, I2S | Tube output stage. Separate psu | $ 15,470
https://hoved-fi.dk/viewtopic.php?f=17&t=2845#p51472
Словно кто то рядом пенопластом по стеклу…
Впечатляющая подборочка. В основном некромантия, и только очень немногие смотрят в будущее.
Хотяяяяя… узнавал у знакомого китайца, где они вагонами берут NOS tda1541/pcm63 спустя 20 лет после снятия с производства. Ответил, что на современном оборудовании сполировать чужой чип не составляет особого труда, а уж насчет производства мы и так давно знаем. Так что музыкальные жемчужинки из прошлого клепают в поте лица уже несколько фабрик.
:slight_smile:
Как раз в том, что настоящие мультибитные чипы (а не китайские клоны) давно нереально купить. Мой знакомый автор закупает в америкозии старые студийные пульты и потрошит их, иначе шанс попасть на липу - процентов 98.
Резисторы же будут выпускаться всегда.
К слову, алгоритмы обработки сигнала применимы не только к матрицам на россыпи, но и к любым интегральным преобразователям. Вон недавно вскочил Waversa (если я ничего не путаю) аж с двумя толстыми FPGA (aahhhh) и четырьмя дешманскими Сабрями мобильной версии. По словам продавцов, уделывает всех. Я не уточнял, впрочем, чем именно… :zipper_mouth_face:
Гилёву тоже очень понравился.
А Гилев продаёт или покупает?
Не знаю.
На сундуке Валерий довольно конкретно написал о преимуществе Рокна над Ваверса. Низкоуровневое разрешение, тембры, вот что за хорошим R2R.
Кстати, опираясь на это мнение, я сделал выводы что и Terminator будет предпочтительней Ваверса, так как динамика у него лучше Рокна и верхний диапазон более открытый.
Waversa оказался достойным DAC’ом. Тональный баланс выше всяких похвал, звук без окраски. Динамика лучше, чем у Rockna. Низкоуровневое разрешение одно из лучших, что удавалось услышать на серийных чипах и многократно превосходит ранее слышанные реализации Sabre 9018, но все же не дотягивает до Rockna.
Подавляющего преимущества я не заметил, больше нюансы в подаче материала, кроме того:
Manhattan 2 по динамике и разрешению уступит Waversa, не смотря на то, что этом Майтеке более совешенный чип 9038
Я давно подозревал, что чип - это ещё не всё.
Ну, я и говорю, если рассматривать как реализацию Sabre, то замечательно. Как только рядом поставить хороший R2R, так сразу “не дотягивает”. :wink:
Вот и я в отзыве Валерия отметил, что преимущества Ваверсы слышно на любых трактах, а вот Рокну надо ещё постараться расслушать. И рок на Ваверсе звучит однозначно лучше.
Что там стараться, если компоненты и АС сбалансированы по тоналке, то её слышно сразу. В теме Рокна много людей с хорошими системами оценили её достоинства. И не понимаю, как с худшим разрешением можно лучше отыграть рок? Динамика у Рокна всёровно хорошая, даже если чуть уступает Ваверса и Терминатор.
Это уже В.Гилёву вопрос.
Наверное чуть лучшая динамика для рока важнее чуть лучшего разрешения? :slightly_smiling_face:
Значит его “подкупила” высокая динамика. В своё время на Манхеттен металл тоже интереснее звучал, зато на БСО…
А высокая динамика плюс разрешение R2R это уже к Терминатор. :grinning:
Я думаю Адажио тут посильнее будет.:slightly_smiling_face:
Дельтасигма, за счет компрессии, рок всгда лучше отыграет. Тема то про R2R.
Не всегда. :wink:
Плюс, просьба объяснить феномен компрессии на дельтасигме. :fearful:
Метрум Адажио? И какой аргумент в пользу “посильнее”, кроме “я думаю”?
Если это уровень преобразования Паване, то нет.) 24бит Адажио против 26бит +6бит DSD у Терминатор. Паване не сильнее Рокна на MSB 24бит. Хотя уровень Паване это уже очень хорошо, но есть и в нём недочёты баланса, разрешения.
Помимо этого нет I2s входа, а у транспортов всё чаще появляются такие выходы и они, как пример SW, лучшие. DSD тоже мимо.
По характеристикам если, хороший ЦАП. Нравится?
