Продам новые звуковые карты:
JCAT USB Card FEMTO от JPlay
JCAT NET Card FEMTO от JPlay
Карты новые в использовании не были.
Гарантия 1 год.
Цена каждой карты 422 евро.
Гарантия 1 год.
Сергей, а можно чтоб не искать, добавить сюда ТТХ, есть инфа??
LAN карточка ( информация с оф сайта):
1st ever audiophile network interface. Ships now!
Setting up a media server on a PC or using a computer as a network audio renderer (endpoint) is easy nowadays. But the problem with computers is that they were never designed with audio in mind. While there are improvements for USB-based playback available, the network controller part of a PC remains noisy.
JCAT puts an end to imperfections of network playback with NET Card FEMTO – the ultimate network interface designed specifically for transferring high-quality audio over LAN.
Specification:
• Audiophile PCI Express GbE LAN adapter
• Ultra-low noise linear regulators and filters eliminate noise interferences from PC
• No switching power supplies anywhere
• FEMTO Clock Technology (Crystek CCHD-957) lowers jitter below measurable levels
• Industrial grade components with operating temperature range from -40C to +85C
• Enterprise level Intel i350 Ethernet controller
• Gold plated high durability EMI shielded RJ-45 connectors
• Two LAN ports supporting up to 1Gbit connection speeds
• LED-off feature to counteract noise
• Requirements for optional PSU: 5V/1.5A min (the 200W Linear Power Supply or 400W PC Linear Power Supply recommended for best SQ)
• PSU can be supplied from computer PSU via LP4 connector or from an external PSU via 2.1/5.5mm center positive DC jack connector
• Low-profile & full-height laser cut PCIe brackets included
• All x1-x16 lane PCI Express 2.0 slots supported
• Supported operating systems: Windows (all editions) and Linux
USB карточка (информация с оф сайта):
The ultimate military grade USB Audio output for desktop PCs
Specification:
• Audiophile USB Audio output for USB DACs & USB-to-S/PDIF converters
• Top quality military grade linear regulators and filters eliminate noise interferences from PC
• Femto Clock Technology (Crystek CCHD-957) lowers jitter below measurable levels
• uDP720201 NEC controller works on Windows and Linux
• High durability gold plated USB connectors
• Two USB 3.0 connectors supporting Low Speed (1.5 Mbps), Full-Speed (12 Mbps), Hi-Speed (480 Mbps) and Super-Speed (5 Gbps) data rates
• 5V PSU can be supplied from computer PSU via LP4 connector or from an external PSU via 2.1/5.5mm center positive DC jack connector (the 200W Linear Power Supply or 400W PC Linear Power Supply recommended for best SQ)
• Both full-size and low-profile laser cut PCI-e brackets included
Закройте пожалуйста
