У меня обычная была, серийная.
С 502 rev4 именно так и было. Писали и напрямую и на площадках типа SBAF и CA. Так победили.
Ну а с pi2aes rev1/2 - никто нигде и не писал изначально, не отбивали…((
Странно как то…
Наверное потому что разница не такая большая 4ак между ревизия и 502. И возможно ревизии 502 до 4ой были более доступны, чем ранние ревизии pi2aes до 3ей
Откуда инфа?
А есть статистика, есть ли какая-то зависимость от качества звука от входного напряжения?
PI2AES-LITE
The PI2AES-LITE, designed and manufactured by PI 2 Design, is a professional I/O Shield designed to bring Professional Studio Grade Audio to the Raspberry PI ® 3, 3+ and 4 series of Single Board Computers. This HAT compatible board converts the Raspberry Pi ® I2S Interface to High Definition AES Coax, SPDIF and Toslink Digital Audio Outputs. Fully Compatible with all PI2AES software.
The major features of the PI2AES-LITE are as follows:
- FORM FACTOR – Raspberry Pi ® HAT Size w/40-Pin mating connector.
- AES TRANSMITTER – The industry standard WM8804 converts the PI I2S stream to AES3/SPDIF formatted data at 24-Bit up to 192Khz Frame Rate. The PI2AES-LITE works with the industry standard WM8804 w/multiple clocks, Linux driver.
- MULTIPLE SIMULTANEOUS OUTPUTS – All output ports are active with the same Digital Audio Data , Bit Depth and Frame Rate at the same time. No further configuration required.
- AES COAX OUTPUT – A 1:1 Isolation Transformer provides Bit Perfect Impedance Controlled Coaxial Transmission of the Digital Audio Data.
- SPDIF OUTPUT – A 1:1 Isolation Transformer provides Bit Perfect Transmission of the Digital Audio Data via RCA Jack.
- SPDIF OPTICAL OUTPUT – Isolated Optical Transmitter Drives Consumer Level DAC and AVR.
- HIGH RESOLUTION CLOCKS – A pair of Ultra-Low Noise NDK NZ2520SD oscillators allow the WM8804 to operate in non-PLL mode for the lowest possible noise.
- ULTRA-LOW NOISE LDO’s – Dual Ultra-Low Noise LT3042 LDO’s (0.9uV noise and 80dB PSRR) is used to Supply the WM8804 Transmit Section and the High-Resolution NDK Clocks.
- LOW NOISE PCB LAYOUT – Constructed with 4-layer Split Ground PCB with noise reduction techniques refined from years of High-Speed Mixed-Signal Design.
- EXTERNAL 5V POWER - The PI2AES-LITE is designed to operate on 5V from the Raspberry Pi. Optionally, external 5V can be supplied for use with low noise Linear PSU’s
В чём отличие от PI2AES? LITE = что-то где-то урезано? Скока будет стоить?
Родные 5В видятся как бонус наоборот.
Сравните картинки самостоятельно.
Цены пока нет.
249 бакса цена в магазине.
И 749 в комплекте с малиной?
Надеюсь на опечатку. Хотя кого я обманываю.
Заберите кто-нить мой pi2aes с доработками Дениса. Точно не хуже чем лайт будет)
Питание себе оставил?)
Точно. Как и pi2AES, но кейс (прозрачный) в комплекте.
Что смущает, так это коаксиальный(!) AES/EBU выход на BNC гнезде. Т.е. интерфейс вроде симметричный, но идёт по коаксиалу, там же 2 проводника, нет?
там же есть и от малины и от внешнего БП.
габариты намного меньше же. Можно микро-стример делать.
Под формат RPi Zero W, RPi-3A+.
Такой выход AES3id называется. Причём он может быть не совместим с обычными SPDIF устройствами. Во путаница начнётся, когда аудиофилы начнут по старинке свои BNC/RCA кабели пихать. На бумаге этот AES3id может покачественнее AES/EBU и SPDIF быть. Но это похоже сугубо студийный интерфейс. Для меня новый. S/PDIF Digital Audio Compared with AES3id | TV Tech
Цифровой звук S/PDIF по сравнению с AES3id
Опубликовано TVTechnology _ 17 января 2006 г.
AES3id, несбалансированная физическая форма стандарта цифрового звука AES3, — не единственный тип цифрового звука, который может быть доступен по коаксиальному кабелю.
В потребительском цифровом аудиоформате, обычно называемом S/PDIF (формат цифрового интерфейса Sony/Philips), также используется коаксиальный кабель. Однако разъем, а также формат отличаются от AES3id.
Там, где AES3id указывает разъем BNC, устройства с входами и выходами S/PDIF используют разъемы RCA. (S/PDIF также может появляться на оптических соединениях.)
Максимальное выходное напряжение для AES3id составляет 1,0 В от пика до пика, а для S/PDIF — 0,5 В от пика до пика.
В то время как S/PDIF и AES3 имеют общий формат для битов, представляющих фактические аудиосэмплы, значения и функции некоторых битов состояния канала различаются. И эти различия могут означать несовместимость при попытке их взаимодействия.
В частности, один бит используется для определения того, является ли формат цифрового аудио профессиональным (AES3) или потребительским (S/PDIF). В зависимости от установки этого бита функция некоторых других битов субкода изменяется. Например, если установлен потребительский бит, другие биты функционируют как код защиты от копирования SCMS. В профессиональном режиме нет битов, предназначенных для защиты от копирования.
Для некоторых единиц оборудования важна установка битов состояния канала, в то время как другие могут их полностью игнорировать. Таким образом, для некоторых взаимосвязей все может работать нормально, а для других - проблемы.
Если вы испытываете проблемы, такие как хлопки и щелчки или вообще отсутствие сигнала при соединении цифровых аудиоустройств, и вы уже проверили, что частоты дискретизации одинаковы и привязаны друг к другу, проверьте, отличаются ли сами форматы.
ну так то там еще БП линейный как правило нарисовывается, и его микро никак не получается сделать, разве что импульсник. ну т.е. размер в принципе не определяющее, как мне кажется
