Может…но знакомый покупал ГУ в авто, с Али кстати, прокатило, цена то же $ около 550ти…значит как повезет …куплю- напишу, чего спорить ни о чем…
Вроде бы нигде не писали об отмене вступления в силу нового минимального беспошлинного порога трансграничной покупки в 100 евро с 1 июля с.г.
Да, это как повезет. Проверки выборочные, на тотальные у них ресурсов не хватит. Ну, удачи.
Тем временем скоро должна стать доступна двухчиповая конфигурация (модулятор+цап)
The AK4191EQ is a premium delta-sigma modulator with multi-bit output employing VELVET SOUND technology. It has increased the oversampling rate of digital processing to 256x from the previous 8x. This allows for aliasing artifacts due to sampling to be driven even further into the upper frequency range.
Additionally, the AK4191EQ’s digital filters can reduce noise by 50dB more than previous devices. A wide variety of music can playback by inputting 1.536MHz PCM and DSD1024 data.
Key Features
256x / 128x oversampling processing
Equipped with 64-bit 256x / 128x digital filter
Equipped with digital attenuator
The AK4498EQ is a product of AKM’s VELVET SOUND Premium Audio manufacturing process, also used for the flagship AK4499EQ DAC and the preceding AK4497EQ. This process results in much-improved noise immunity in general, and increased low-frequency noise performance in particular.
While conventional DACs use a single chip to convert signals from digital to analog, new products split the conversion process between the AK4191EQ delta-sigma modulator and the AK4498EQ DAC. This innovative approach has resulted in an improvement in sound quality that is easily perceptible while listening to music.
(AKM is the Asahi Kasei Microdevices Corporation)
Key Features
Low distortion and wide dynamic range S / N = 128dB (2Vrms output)
Equipped with newly developed switched capacitor filter “OSR doubler”
Multi-bit Modulator Data Interface with 11.2896 MHz Clock
на братском форуме обзорщик в лоб сравнивает Singxer SDA-2 с RME ADI-2 DAC…чел очень высокую оценку дает Singxer SDA-2, вот )))
Может кто слушал такой цап
Ничего себе цена!
Читал, когда выбирал себе Singxer. Писали, что собран в подвалах дядюшки Ляо с соответствующим разнообразием звучания в следствии непредсказуемости качества сборки.
Читал обратное про фирму WEILIANG аудио , усилители и цапы выпускают высокого качества .
Выброшенные деньги. WEILIANG со своим инженерингом остался в прошлом. 5-7 лет назад, когда китайцы только пробовали зайти в аудио.
Да ладно! И что же это за усилители?
Усилители правда копии , но всё равно сборка отличная . У меня усилитель Худа 15 ватт от этой фирмы .
Откуда знаете? Предполагаете? Фантазируете?
Там детальности столько, что Вам не унести. Там детальность ошеломляет. Не цикание и не бумкание, а детальность.
У меня был такой. Только на 4497.
Продал и перекрестился.
Арес на две головы лучше.
И цена тоже на две головы выше , на 4497 у них 4 версии , какую Вы брали ???
Ещё варианты будут?
Слушал ЦАП на TDA1543
Где прям так много? Поделитесь, я как раз выбираю ЦАП, вдруг понравится.
Продолжайте в том же духе, Вы на правильном пути!
Можете купить себе сразу одну из “конечных остановок” в ЦАПах. Если поторопитесь…
Хотя, всю жизнь перебирать топпинги тоже, видимо, по-своему захватывающее действо… Тем более модные чипы выходят каждый год, а вчерашние фавориты сразу же превращаются в тыкву, как старый айфон…
К сожалению, не понравился, но должен заметить, что там реализация была так себе.
Это взрослый ЦАП, для большой стационарной системы.
Мне нужен попроще, настольный, для компа и наушникового сетапа.
Но, всё равно, спасибо.
“Перебирать” в таком контексте, это в принципе, удел человека увлеченного. Пока найдешь “свой” звук, переберешь ни один десяток аппаратов. Собственно, почему бы и нет? Некоторые вон кабели перебирают Главное - бесценный опыт и удовольствие от процесса
Если будете перебирать условные топпинги, Вам придётся менять ЦАП каждый год или чаще на новинку с более модным чипом и каждый раз разочаровываться, ведь звука опять нет… А я же и пытаюсь Ваше “перебирание” направить в нужное русло. (Точнее, это бар и бармен @dmitre пытаются). Почитайте тут в Баре есть интересные ветки по тем же ЦАПам, где многое обсудили уже, но это все старье, конечно…
