Можно ещё кое что попробовать. Поковырять шифрование в винде. У вас там с системой очень непросто все. Ох уж эти сборки с рутрекера…
Появилась версия 4.4
New features
- NEW: Raspbian Stretch Lite 2018-11-13
- NEW: Support for Raspberry Pi 3A+
- NEW: Clock radio days-of-the-week setting
- NEW: Customize settings for compilation rollup and excludes
- NEW: Auto and manual settings for Hi-res thumbnails
- NEW: Library multi-disc breakout for tracks
- NEW: CoverView dynamic background effect
Radio stations
- NEW: CBC Radio 2
Updates
- UPD: Bump to Linux kernel 4.14.84
- UPD: Bump to shairport-sync 3.2.2
- UPD: Add entry for “On-board audio device” to cfg_audiodev
- UPD: Add exception logging to coverart and thumbcache.php
- UPD: Add failsafe loop exit to Zend Flac.php
- UPD: Add RT params to mpd.service and rotenc.service units
- UPD: Disable Spotify audio file cache
- UPD: Use plughw in startSpotify()
- UPD: Change method used to empty the thmcache dir
- UPD: Optimize CSS for large Playlists
- UPD: Only load swipe JS when mobile
- UPD: Use GNU cmd syntax in rotenc and volume scripts
- UPD: Add disk utilization to sysmon.php
- UPD: Add revision code 9020e0 for Pi-3A+
- UPD: Add Close to all context menus
- UPD: Improve spacing on Radio and Album cover panels
- UPD: Add 30px blur to list of Cover blur settings
- UPD: Improve performance of Library loader/filter
- UPD: Include moOde version in SSH motd header
- UPD: Deprecate workaround for obsolete Katana 1.0
- UPD: Full screen input source indicator
- UPD: Deprecate vol.php
Bug fixes
- FIX: Blank image thumb on Customize in certain scenarios
- FIX: Modal control spacing when full screen
- FIX: Librespot fail on armv6l (Pi 1B, Zero, Zero W)
- FIX: Thumbnails not generated for mp3 embedded covers
- FIX: Title sometimes out of sync (radio station)
- FIX: Fallback sort for Albums by Artist
- FIX: Extra metadata not showing encodedAt rate
- FIX: Thumbcache fail on paths containing #
- FIX: Library track sort not using disc number
- FIX: Regression bug in Sources Re-mount
- FIX: Bad icon reference in the eq templates
А новую версию можно сверху накатить, или опять переустанавливать нужно?
Я просто обновил.
Как по звуку?
Ещё толком не слушал.
Дмитрий, я думаю пока повременим, но спасибо за предложение.
Звук нравится больше когда подключен HDD через юсб, но возникла новая проблема,
винчестер через половину трека просто замирает вместе со звуком, подключен двухвостым кабелем, один конец в малину, один в пауэр банк, питания малине и венику вроде хватает. Лампочки не гаснут.
Попробуйте в настройках Audio - MPD options увеличить значение буфера в поле “Buffer fill before play”. По умолчанию там 10% стоит. Там же можно проверить не включен ли SoX ресемплинг. Если да, то отключайте. Кстати, попробуйте перед этим протестить с как играет с флешки.
Подскажите в малине вообще ROM никакого - все с карты?
Все равно, буфер сделал меньге, sox ресемпл был выключен.
Но когда убрал буфер в принципе выключив его, стало играть на 1 композицию больше, может тут дело в hdd (гибридник) и кракозябре 3х хвостой ?)
Это неожиданный результат.
да согласен, и сложилось впечатление что когда больше обращений к hdd т.е шаришься по нему (в moode) в поиске композиции играет без сбоев, только ушел в сторону, перестал искать и открывать папки, все, через минуты 3-5 заглохнет.
Нужно смотреть мануал ии искать Powersave режим, а также софт фирменный который его отключ/вкл.
мануал hdd ?
софь чего ? малины веника муда ?)
Винт засыпает поскольку запитан отдельно (я так думаю) Софт винта Провертьте еще сколько музыки в плейлисте муде -мож вы одну песню проиграли и встали?
и если он есть, имеется возможность его поставить на малину вместе с муд?
не совсем, он потребляет питание и малины и отдельного источника питания. как я это понимаю.
у них (винтов) есть smart там можно настьроить эко режим при котором винт будет засыпать при отсутствии запросов (это я предполагаю) У меня один вербатим тоже теряется пока его проводником не “пнешь”
В Moode нет экорежима.
Значит и так не канает, придется колупать сеть дальше
Не в мооде в винте эко режим
