Присоединяюсь к вопросу. Методом тыка попробовал - не получилось.
Компы, железо, Intel Nuc, Roon Labs Nucleus для Roon — всё об источниках, поддерживающих святой ROON
Я тоже прописал ip и в итоге рок вообще не виден, не хочу с нуля все ставить.
Вот тоже интересно.
А то из-за этого и сижу на простом ноуте и винде.
Хотя и так нормально. )
Это точно можно, на рун форуме нашел такое:
NUC (Intel) ethernet 1 port:
ip: 5.1.1.1
netmask: 255.255.255.0
gateway: nothing
dns: nothingNUC (USB Ethernet adapter) ethernet 2 port:
DHCP (you can set-it up as static IP but use the IP within your subnet.)sMS-200 IP:
ip: 5.1.1.2
gateway: nothing
dns: nothingROCK will provide the IP of your LAN network that was set in DHCP. For example: 192.168.0.x or 10.10.10.x. This is the IP you will access from your Roon remote (browser). IP’s 5.1.1.1 and 5.1.1.2 cannot be accessed from your browser because they are now in a different subnet.
Т.е. подсеть создается в сети. Но я еще нашел там такое:
One more question in regards to this dual ethernet setup. If access to internet is provided through the usb-ethernet adapter and an endpoint is directly connected to the lan input of the NUC running ROCK, is it possible for the endpoint to have internet access? In other words, can the internet connection be shared from the port connected to a router/switch to the other port which is directly connected to the endpoint?
This is very important for me because my endpoint is the dCS Network Bridge which supports AirPlay. I use Apple TV 4K as a media player where I send video through hdmi to my tv, and audio through AirPlay to the dCS NBR. In Windows 10 I was able to bridge connections and have direct connection between the PC (Roon core) and endpoint, and still have internet access on the endpoint part.
Since migrating to ROCK, if I wish to use AirPlay I need to disconnect the dCS NBR from ROCK and connect it to my switch. The frequent plugging/unplugging of cables can be pretty tiring if it happens several times a day.
Похоже мне такой вариант не подойдет, если я хочу airplay использовать с бриджом.
Включил систему. Блииииин, мужики, реально лучше звук стал с нюком, прям с первых нот услышал и у меня развязка оптикой. И шустрее стало все работать!
Это в какой нюк? Сайррус уже прибыл?
Я вырубил системник и снес триал, разница ощутимая с мозайкой((
Не пока так, сток:
То есть пока без моста, штатно?
Добавлен NUC + ROCK?
Да.Тоже вчера установил Rock на новый NUC,только приобрёл…Супер ! До этого слушал со Squeezeserver установленном на NASe Synology .Разница огромная! Не знаю как люди не слышат различий!)
Да и похоже буду без моста. Dcs bridge не будет виден в сети, если мост делать и нельзя будет использовать его через airplay
Ну я и между одной и той же системой различия слышу. Вчера включал не играло, сегодня включил играет. Только вряд ли там что-то изменилось. Вот когда вслеппую отличить сможете сервер на нюке от сервера на другом компе тогда есть смысл о чем-то говорить)
Не Вы один такое слышите.)
Roon на нуке. Основная сеть 192.168.1.1 К нуку подключил вторым usb-ethernet. На снимках экрана видно как прописал адреса. Рендер сотм, его настройки тоже на экране. Нук соединён с сотм прямым линком, но через медики. Минус только один - с сотм общается только рун, я не вижу веб интерфейс сотм, но и не надо
Вот блин как все для нормального человека сложно достался мне цап с юсб. Пробую разные варианты с ноутбука (вин10) через юсб шнурок - лучше всего звучит roon. Лучше Аудирваны, Альбом Плеера… Звук с головой устраивает. готов расстаться с $120.
Не нравится проводки, ноутбук, который приходится таскать - думал есть решение с небольшой коробочкой, которую засунул поглубже под тумбочку и никаких проводков… теперь понимаю, что просто интел нук с рун роком и от него юсб шнурок особой разницы мне в звуке не даст… выиграю только в размере. А так нужно городить целый огород, в котором я мало что пока понимаю… И главное добавляется куча проводков и коробочек …
Как я понял интел нук с рун рок будет ядром и хранить информацию о моей медиатеке (в данном случае с тидал), дальше он как-то должен связаться с сетевым плеером (опять через какие-то провода и коробочки), а затем от этого плеера (например какая-то малина) передается сигнал на цап (только опять не по юсб и мне нужен другой цам с цифровым входом) И это будет звучать лучше? хотя, как я сказал меня и этот устраивает вполне.
Простите за неконструктивный пост, Не могу пока в этом разобраться…
Если цап хороший, то купите юльтраренду, нюк будет сервером, ренду стримером. Наверное самый простой вариант, если юсб в приоритете, но коробки будут да, как минимум ультре нужен линейник.
Спасибо. Поискал конечно, что такое утльтра))) короче понимаю, что в руне особенного смысла нет, если вот так с компа… там и аудирваной можно обойтись…
а если искать стример, то проще тогда готовое решение (в моем случае naim nd5xs2) да дороже но не в десять раз - раза в два-три не больше, зато красиво понятно и по звуку лучше в любом случае…
PS: а есть стримеры, которые можно связать с рун ядром по вайфай? Понимаю, что вопросы наивны - только пытаюсь вникнуть в тему…
Вот тут: ранее, Богдан сделал небольшой экскурс в Roon. Боюсь, сделать правильные выводы про рун, невозможно, не пощупав его самостоятельно. В нём есть недостатки, но его юзабилити становится понятно только в практическом процессе…
Так, что, советую попробовать его, просто на компе. Оторваться будет сложно
Если стример поддерживает это, то несомненно… Я например пользовался ChromeCast Audio. По сути это и есть, стример по вай-фай ))
Спасибо. Короче нужно учить матчасть описание рун читал, начинаю понимать, как это работает и пытаюсь понять, как построить у себя или забить и слушать.
Ну как я и говорил выше, просто поставьте пробную версию Roon на компе, откиньтесь в кресле и получайте удовольствие… А потом разберётесь )))
Вот отличное готовое решение:
https://us.auralic.com/products/aries-g1?variant=30892280643717
Рун, не рун, вайфай - всё умеет и звук хороший.
