Интересно, что это за отверстия?
В Титанисе 2.0 и 2.1 есть такие же и функционал у них скорее всего одинаковый.
Цеж малинка и без шляпы ![]()
Наоборот, со шляпой и шляпа большая, с полями - самбрэро!)
Jeff Da, the manager of Holo Audio:
Holo Red Streamer + DDC, the Streamer core uses the Raspberry Pi Compute Module 4 as the main axis of the computing brain. Not a generic Pi4.
The difference from the finished Pi 4 is. The finished Pi4 is developed for the convenience of users. All accessories have been finished. All configurations around the core have been set. For example a USB line. power lines etc. There is no way to change the setting. So the sound performance of the Pi4 kit is not high.
Chinei is a set of Pi Compute Module 4, which is a set of core module. That is, only the brain. The hands and feet of the surrounding lines are carried separately. You can cut off everything that has nothing to do with the sound. Make a good line that is good for the sound. Equipped with LPS linear power supply line. There is also an excellent DDC configuration. In addition, configure the Holo own program. Streamer + DDC 5~6k price. Can do Roon Bridge, Spotify, Tidal, etc. Streaming. High cost performance. Born for convenience + acoustics.
The Raspberry Pi mainly has good software support, and there are various free software for it. The hardware of the Raspberry Pi is really not very good, so we use the core module of the Raspberry Pi, so that the peripheral circuits and power supply can be provided by high-quality circuits. Complete, and at the same time compatible with various Raspberry Pi software.
We’re not using an entire Raspberry Pi! Just use its core!
Early bird order today. The delivery period is around the Lunar New Year.
If you are interested, please contact me to check the price as soon as possible.
GoldenSound анонсировал полный набор измерений по Holo Red, а пока сказал:
RED has the lowest jitter of any DDC/Streamer I’ve tested. First thing to beat the Wavedream NET
Well done Jeff
Появилась некоторая часть характеристик Holo Bliss:
HEADPHONE OUTPUT
4P XLR Output
Low impedance mode (LO-Z): Output impedance 0Ω, power 12Wrms@32Ω
High impedance mode (HI-Z): output impedance 15Ω, power 2.5Wrms@150Ω
4.4mm Pentaconn Output
Low impedance mode (LO-Z): output impedance 2Ω, power 12Wrms@32Ω
High impedance mode (HI-Z): output impedance 17Ω, power 2.5Wrms@150Ω
6.3mm TRS Output
Low impedance mode (LO-Z): output impedance 1Ω, power 3Wrms@32Ω
High impedance mode (HI-Z): output impedance 8.5Ω, power 0.6Wrms@150Ω
В четыре раза больше мощности чем было у Holo Serene (она могла выдать только 3Wrms@32Ω) и если её хватало для большого количества наушников, то Блисс вероятно должен качать всё физически совместимое.
В принципе на сайте KTE это и заявлено:
Enough power for any headphone!
Цифры заявлены большие. А вот как на самом деле, сможет ли потянуть самые тугие, типа Абиссов или LCD4, например, это надо ещё проверять на практике.
Цыганщина
, но мне нравится (нашли “свое”).
На сайте европейского диллера Holo Audio - MagnaHiFi появилась страница с Рэдом и начался предзаказ.
Выложили характеристики и много новых качественных фото. Пока только непонятно, что с DSD, GoldenSound говорил, что 512 - это максимум, а у Магны 1024 написано. Правда у Голдена не было родного софта, может в этом дело.
Цена конечно у Магны сильно выше чем у Wildism, последние отдают Рэд первым покупателям, примерно, за 755$.
Авитошные “продавцы” тоже открыли предзаказ:
https://m.avito.ru/sankt-peterburg/audio_i_video/holo_audio_red_setevoy_strimer_i_ddc_i2s-dsd1024_2632202425
Также есть на Алиэкспресс с доставкой в декабре https://aliexpress.ru/item/1005004971223355.html?sku_id=12000031198405372&spm=a2g2w.productlist.list.4.6f441b37xmms4K
Сейчас уже появилось больше информации
HoloAudio “RED” is a Network Streamer with I2S HDMI output
Делается акцент именно на качество работы hdmi i2s выхода ![]()
Holo Red can be used as DDC (USB to I2S or SPDIF converter). To activate the DDC function the Red must be turned off/on while the USB source is connected. to re-enable the Streaming function, disconnect the USB source and turn the Red off/on again
Может использоваться и как DDC конвертер - Red переходит в этот режим если подключён USB источник и устройство перезагружено
DSD Native Support notice: Red can support up to DSD512 and PCM768K by I2S. USB is limited by linux kernel and also support DSD512 and PCM768K right now, new kernel will support DSD1024 and PCM1536K in future release
По i2s hdmi DSD512 и PCM768K - это максимум (но есть теория, что на цапах Holo начиная от Spring 2 и выше, где “no longer using LVDS and are now using a custom 4way circuit that isolates each line which further improves sound quality. such as the MCLK is isolated from data line and this improves jitter spec” - итоговые цифры будут выше)
В свою очередь, возможности USB выхода пока лимитированы прошивкой и чуть позже достигнут максимума в PCM1536K и DSD1024 ![]()
На данный момент поддерживаются:
Вот только один вопрос - а nahua? Что слушать?
Это уже начинает напоминать “борьбу” (маркетинговый ход) за мегапиксельность, в свое время в цифровом фото?
Как что, гуанооцифровки винила, главное что-бы они весили дохрена))))
Для оверсемплинга через HQPlayer (есть тема) - подробней на видео
Главное, чтоб умели 1:1 играть)
В том то и дело, как с мегапикселями, к качеству звука это уже очень неоднозначное отношение имеет, больше похоже на маркетинг.
В студийном PCM больше 384 пока нет, а найти студийный DSD 512 большая редкость, как впрочем и на слух “поймать” разницу между 256 и 512.
Есть у нас в баре храбрецы из фан-клуба Холо, кто уже сделал предзаказ на Holo Red?
На сайте KTE появилась страничка с Рэдом и стартовали продажи по цене 798$.
А тем временем Wildism Audio активно приглашают на прослушивание Holo Red, Holo Bliss и другой продукции Holo Audio у себя на студии в Гонконге:
Кстати говоря, Рэд стоит на аудиосвитче LHY SW-8 набирающим хайп в сетевой теме:
