echo Optimizing Processor Resource scheduling:
echo Turning the paging file off:
echo Disabling Hibernation
echo Disable Data Execution Prevention
echo Disable User Account Control
echo Disable Action Center
echo Disable Lock Screen
echo Changing IRQ Priorities:
echo IRQ8 = RTC Timer
echo IRQ0 = System Timer
echo IRQ12 = Mouse PS/2
echo IRQ13 = Numeric Data Processor
echo IRQ1 = Keyboard
echo Turning off USB Power Managment for USB Root Hub Devices
echo Turning off all visual Effects
echo Disabling OVER 180 drivers and services…
SET /P ANSWER=Do you want to disable remote dektop? Press Y for YES or N for NO (or if you are unsure)
SET /P ANSWER=Do you want to disable WiFi? Press Y for YES or N for NO (or if you are unsure)
SET /P ANSWER=Does your computer use an Intel Processor? Press Y for YES or N for NO (or if you are unsure)
echo You pressed Yes so AMD Processor Services will be disabled
SET /P ANSWER=Do you want to turn off all Network access? WARNING! If you choose YES ALL network access is stopped nor will you be able to access a NAS drive!
SET /P ANSWER=Does your computer use an IDE/ATA HDD or SSD? This is older technology - SATA is more common. Press Y for YES or N for NO (or if you are unsure)
SET /P ANSWER=Does your computer use a Firewire Interface? Press Y for YES or N for NO (or if you are unsure)
SET /P ANSWER=Do you wish to use WASAPI or HDMI for audio playback? Press Y for YES (or if you do not know) or N for NO
echo Turning off all 21 Startup Event Trace Session Logs
echo Setting power scheme to HIGH PERFORMANCE
echo Disabling USB Selective Suspend settings
echo Pausing Desktop Background settings slide show
echo If laptop lid closed - no action
echo Disable PCI Express Link State Power Managment
echo Set Minimum CPU state to 100% (No Throttling)
echo Set Maximum CPU state to 100% (No Throttling)
echo Intel Graphics - set for maximium battery life
echo Set system cooling to passive
echo Turn off display after 1 minute
echo Never turn hard disk off
echo Never allow the computer to go to sleep
echo. Turn CPU Parking OFF
echo Your computer will now reboot when you hit any key…
Навскидку практически ничего противозаконного, особенно для “музыкального компьютера”.
Кстати Album Player при запуске тоже много чего корректирует в Windows “в свою пользу”.
По факту, скрипт: оптимизирует работу процессора для максимальной производительности программ, отключает файл подкачки, отключает режим гибернации, отключает функцию Data Execution Prevention, отключает контроль данных, отключает Action Center, отключает блокировку экрана, изменяет приоритеты прерываний (для RTC Timer, System Timer, Mouse PS/2, Numeric Data Processor, Keyboard), отключает управление питанием для USB, отключает визуальные эффекты, отключает более 180 служб и драйверов не связанных с воспроизведением аудио, по выбору может отключить удаленный рабочий стол, отключает специальные сервисы для процессоров AMD, если установлен проц от Intel, отключает все сетевые службы если комп автономный, но можно оставить сеть и отключить WiFi (однако можно оставить), позволяет отключить поддержку старых интерфейсоф IDE/ATA и неиспользуемый Firewire, позволяет отключить WASPI и аудио через HDMI, отключает все функции Win8 ( все кроме поиска), отключает Log и события отслеживаемые при старте, переводит комп в режим максимальной производительности.
Положительный результат оптимизаций легко определяется на слух, к тому же прилагается скрипт возвращающий старые настройки.
Единственное, что хочу отметить. Несмотря на настоятельную рекомендацию отключить WiFi и использовать только Ethernet мой неттоп с NAA звучит лучше по беспроводному интерфейсу (возможно нужен аудиофильский Ethernet кабель и качественное питания для роутера чтобы “медь” проявила свои преимущества для качественного звука).
Не понятно. Если комп исключительно для аудио, то зачем там поднимать Windows и пытаться из него конфетку сделать?
Linux позволяет полностью контролировать и минимизировать систему. Причем, как уже тут отмечалось, с гарантированным успехом в качестве звука.
Советую у Intel отключать Hyper-threading.
В моём случае при тяжёлой нагрузке от HQP компьютер ведёт себя стабильно и предсказуемо.
Hyper-threading добавляет глюков а прирост производительности под вопросом.
Послушал на чистой 7ке DSC v2.5 + amanero (гены NDK+чистое питание) + ROON+скрипт от Алексея
Действительно, замечательно звучит, даже вроде как и объемней и натуральней чем в MAC OS. Сцена так же “растекается” на всю комнату, инструменты не перебивают друг друга. Очень сильный эффект присутствия исполнителя.
Еще ROON очень понравился своим “отношением к пользователю”, гибко настраивается, можно поглядеть путь преобразования файла. И самое интересное вроде как можно объединять звуковые устройства в одну группу и отправлять на эту группу сигнал. Подключаем несколько AMANERO (при прошивке наверное надо разное имя давать или ID какой ниубдь). Тактовать их от одной пары генераторов, или одна master Amanero + остальные slave Amanero. И заветный многоканал готов?
Алексей благодарю за крайне полезную инфу!!!
Кстати для MAC OS там же тоже есть скрипт, но у меня на hackintosh что то не завелся…
можно ли в нем работать не плейлистами/альбомами/исполнителями, а как в обычном фубаре закидывать папку ?
Воспроизводит ли он он файлы подряд не останавливаясь после первого трека? Как я понял со слов человека, он воспроизводит файлы подряд только если нажать кнопку “перемешать”, в противном случае останавливается после первого трека.
@insert кто то интересовался алгоритмами преобразований SDM? Получите, распишитесь
Получается, при должной сноровке, такую конвертацию “на лету” можно прикрутить на уровне ASLAMIXER ? И получить под линуксом универсальную звуковую карту, на которую любая программа сможет выводить звуковой поток “любого” формата(PCM/DSD) ?
Очередные наблюдения за журчанием свежеспаяной платы и его благополучное лечение.
Собрана очередная плата на 2.6.2.
При первичных обмерах, один канал попал под подозрение:
Постоянка на выходе 4мВ - при норме 0.2- 0,8мВ.
На паузе в данном канале шел едва уловимый фоновый шум(аналогичный “розовому”).
При проигрывании “тишины” - шум полностью уходит, однако при проигрывании очень тихих звуков появлялся коррелированный шум(“журчание”).
Вот тут я и решил поставить эксперимент аналогичный тому, который проводили Виталий, Алексей, Александр и т.д, а именно:
Установить в фубаре минимальную громкость, так чтобы на усилителе ручка громкости была на максимуме. Бегунок громкости в фубаре оказался на ~5% от 100%.
В итоге, в проблемном канале журчание порою было громче даже, чем полезный сигнал.
Постарался в проблемном канале максимально зафиксировать все отклонения от нормы.
Небольшая постоянка на выходе (4мВ)
Едва уловимый розовый шум на паузе.
При проигрывании - шум уходит, но на очень тихих участках появляется небольшое журчание(DSD256)
Напряжение на сопротивлениях( со стороны регистров) разное: на тех что ближе к регистрам - 2,47В, на тех что дальше от регистров -2.50В, на противоположном плече проблемного канала, наоборот: те что ближе к регистрам - 2,5В, дальше - 2,44-2,47В.
Разная скважность меандра у “четных” и “нечетных” резисторов (~49% vs ~50.1%)
При обмерах, при прикосновении щупов мультиметра, фоновый шум в проблемном канале полностью уходил.(При чем не важно в каком канале делался обмер).
В итоге проблема была в малом количестве припоя на земляной ноге буферной микросхемы сигнала BCLK(плохой контакт).
После устранения причины, даже на 1% громкости, журчание зафиксировать не удалось ни в одном из каналов. (Обмеры и прослушка прозиводились с установленными трансформаторами.)
Да не… журчание можно услышать и в Single End режиме( без второго плеча).
Не, не обязательно, я собрал порядка 30 плат и на моей практике журчание от дефекта было всего раза 3 :
не удачно запаялась индуктивность(поверхностным натяжением паяльной пасты индуктивность перетянулось к одному из полигонов) и не было питание на регистре - большая постоянка на выходе и журчание.
Окислившиеся контакты резистора которому 10 лет от роду и как следствие плохой контакт одного тапа в одном из плечей. Так же давало небольшую постоянку на выходе(более 2мВ) и как следствие журчание.
И вчерашний случай с плохим качеством сигнала BCLK.
Подозреваю, что журчание так же может давать:
Не удачные земленые петли(+ импульсные шумы в земле) и как следствие не корректная работа клок сигнала.
пробой мьют ключа и перекос плечей(постоянка на выходе), теоретически так же может давать журчание.
Эксплуатация платы без трансформаторов сразу на балансный вход усилителя - так же ухудшает вычитание шумов переключения.
