Мне не попадались такие.
Оу. А как же он тогда гигабитный через 2.0? Сейчас читаю - да там такой себе гигабит. Странный.
@Maxinada
тогда все печально, хотя там контроллер другой, мб получше будет.
Там сам контроллер другой LAN7515, надо почитать.
Gigabit Ethernet (снова через USB 2.0, обещают до 300 МБит/сек)
Первое что нашел в гугле.
Молодцы какие. Где остальные мегабиты?
Вот что пишут
Сразу выжимка:
POST UPDATE:
I’ve lived with the new Raspberry PI B+ for a couple of days and done some careful testing on it. Of course, my main interest was to back my hypothesis of better USB Audio performances, so I went straight ahead and connected my Pro-Ject Pre BOX S2 Digital (since it can reach up to 32\768 via USB and play DSD 512 in Native mode).
All tests were made with the experimental image that can be found here
As usual, I started playing my “Raspberry killer” track: a 32 bit, 678 kHz .wav file from my NAS. And… What a terrible disappointment: loads of crackles and a whole lot of lost packets.
Tried then with DSD, 24/192 flacs, and even 16/44.1 flacs. All sounded just terrible. So, indeed the new USB BUS did change USB Audio performances, unfortunately, it did for the worst.Luckily though, I then tried to play the same files from a USB drive (and not from a NAS), and magic happened: spotless playback up to 32\768. Seemed that taking ethernet (I was connected on wired connection) out of the equation did the trick. So connected the PI via wifi and restarted without ethernet: same result, HI-Res Music playback was just perfect to my USB DAC.
So, it seems that there is still some issue (hopefully it’s driver related) to the Ethernet controller, which seems to give up lots of packets in high-bandwidth situations. I am however pretty confident that the foundation will solve this issue, as it’s not uncommon that hardware performances get dramatic improvements as software gets tuned up after community feedbacks.
The good news is that there are actually tangible improvements on USB throughput, as I did not experience a single glitch with a great variety of files: 16\44.1,24\96,32\768 flac, DSD64, DSD128, DSD256 and 8X MQA (this is an extremely meaningful test, since if even a single packet is lost the MQA decoding would stop).
So, for now, if you avoid using Ethernet to retrieve your Hi-Res files, the PI 3B+is just perfect to feed your USB DAC with bit-perfect joy.
Итого: если не стримить аудио по эзенету, а забирать его с ЮСБ накопителя, то вроде бы все зашибись. И даже если стримить по вайфаю - тоже ок.
Tам ограничение из за usb 2.0, теоритически он гигабитный.
Ну так я про то же.
Я проэксперементировал с малинным usb вдоль и поперек… по совету @BVLabs взял кубитрек третий на эксперимент и … оставил. в результате он по юсб превзошел малину… да на него только рунаудио. но качество получилось выше чем всё на малине. все имхо. но советую попробовать, если нужна только дырка юсб
Можно ссылки пжл? Почитать,изучить)
Мне в личке посоветовали. Изначально думал спарки взять… плата вот CubieBoard3 – CubieTech на нее сделал зерозон линейный бп на 1083 (ZEROZONE DIY LT1083 Adjustable power supply kit 0-35V DC output | eBay ) с заменой на более качественные кроме 1083 детали.+ Конденсатор на 20т мкФ. ЦАП сейчас в сборке - брио с вегалаб…до этого ак4490. Плату брал в Москве бу, корпус пока в пути. Сборка (runeaudio.com) есть ещё сборка волумио неофиц. но мне качество не понравилось.
Отдельная благодарность @BVLabs хорошо направил…да в волумио есть куча плюсов. Но если просто слушать то и старого рунаудио хватает. Я использую только usb. До этого была малина с диги про, потом 502, потом с cd экспериментировал…пришел э тому решению
сложна для меня
Вы даже на десятую часть не представляете, как сложно
Плата в нее зарядник) флешку…и выход usb. Что малина, что эта… Остальное уже по желанию
Это даааа))))
Ну,в кубике хотя бы раздельное усб,что радует. А вот эта фигнюшка по ссылке,для улучшения питания? много ли она дает?
У меня разница между малиной и кубиком получилась гораздо сильнее, чем между зарядкой и лбп на кубике. Но т.к зарядка одна от телефона и бп в любом случае нужно было собирать, то собрал сразу нормальную. Для пробы сойдёт любая, ну тут рекомендации, как для малины. Для начала просто хорошее питание. (эксперимент не дорогой, что малина 3т, что кубик 3т…дороже не вижу смысла покупать, нужно поискать просто)
Тоже USB-выхода, да?
Угу. Это для тех, у кого хороший ЦАП с usb. Выше спрашивали
Ну что за емае,либо diy какой-то,с пайкой и т.д,либо китайские погремушки или плати 1к+$
А мне просто цифротранспорт нужно,как минимум не хуже ноута. У меня не такая дорогая система будет,чтобы вбухивать на просто транспорт 600 и более евро,хотя и понимаю,что получится только лучше,но потом захочется лучше цап и усь,а там аудифилия и т.д
Только вот кубики сильно дороже малины,попробую для начала малину,чтобы понять,на сколько все плохо или нормально)
Я считаю, верное решение.
Не пойму) написал же кубик 3 тыс р на Авито находите, может только не сразу и пробуете с обычной зарядкой. Если хотите понять разницу то соберите и то и то) либо - опыт других… Если система не сильно хорошего уровня, может разницу и не услышите, тогда не заморачивайтесь и берите малину она более адаптирвана. БП для начала хватит любого за 300-500р. ( Мне diy обошёлся в тыщу)…про 600 евро хорошая шутка в сторону местных разработчиков:smile: хотя любой опыт должен приносить доход)) либо удовольствие
Пс. Кто успеет для эксперимента .на Авито сейчас (Авито доставка вкл) но нужно уточнять чтоб все работало https://www.avito.ru/ishimbay/nastolnye_kompyutery/mikrokompyuter_cubietruck_cubieboard_3_943322963 1500 руб. Кубик 3й
По стоимости мне все обошлось - кубик 3т, плата питания+зч +кондер-1т, торр транс-500р, кнопка на корпус 150р, фильтр питания 500р, и сам корпус 2000р, разъемы на вынос на заднюю панель корпуса lan/usb взял на всяк случай чтоб не пилить под плату аккуратно а вырезать шуруповерта))еще на рублей 200. Итого 7350р Ито потому, что хочу в металл корпусе и с питанием. Как все доедет и соберу -скину, что получилось (часть этого можно было вообще не заказывать…но захотелось)
