не сильно критичны, но хоть 40-50 см надо оставить.
ну как это… производитель рекомендует треугольник и направление сч динамиком строго в голову. вот так они у меня и заиграли… шаг влево шаг вправо сцена уплыла. а еще по басу… не там поставил его и его не стало…
после таких слов, может сложиться впечатление об узкой направленности акустики.
сч драйвер имеет узкую направленность
The subjective performance of any monitor loudspeaker will be influenced by the
acoustic character of the room in which it is used, and its position within the room.
Most often monitors are installed in rooms which are comfortable to sit and talk in.
A mixture of carpets, curtains and soft furnishings will help ensure that middle and high
frequencies are reasonably well controlled. There may however be low frequency
problems; either too much or too little bass. To minimise low frequency problems
the monitors should be kept away from corners or walls. Start with them positioned
on appropriate stands 1 metre from the side walls and 2 metres from the back wall
back walls. for fine tuning rather than to compensate for Use the Bass Boost control
innapropriate positioning. For stereo listening, loudspeakers should be positioned
to experiment with both the listening and speaker position until a good compromise
In professional installations, try to avoid placing speakers on the console/desk meter
bridge. Typically, this compromises the balance of the loudspeaker especially in the
lower mid range. If the balance is bass light, the monitors can be moved towards the
so they form an equilateral triangle with the listening position (See Fig.1).
Loudspeaker stand height should be chosen to position the loudspeaker
acoustic axis at, or close to ear level (See Fig.2). All rooms vary and it is a good idea
is reached. For professional installations the requirements are often very specific.
Please consult with an experienced professional acoustician if necessary. Monitors
Monitors with an asymmetric (offset) driver array should be positioned such that the
midrange driver and tweeter are inboard. If the monitors are to be placed in any form
of cabinet, adequate side and top clearance for cooling airflow must be provided.
Alternatively, the Amplifiers should be removed and installed remotely. All ATC 3-way
loudspeakers are designed with the mid-range dome as the reference acoustic axis.
With this in mind, the loudspeakers should be positioned with the mid-range dome
at, or slightly below ear level (See Fig.3).
хотя на самом деле и не пишут что миды должны быть направлены в уши а только на уровне ушей, но при это картинка в мануале показывает направление мидов в уши, основываясь на том что миды по вертикали должны быть на уши, я делаю вывод что и по горизонтале должны быть в уши и это и мой опыт и Арсена
короче как ни крути а полтосам нужна свобода
Сч купол имеет очень широкую диаграмму направленности по горизонтали, но небольшую по вертикали, поэтому все рекомендации по направлению в уши идут от него именно по вертикальному углу. В остальном вполне свободно играют. От самого помещения может еще зависеть, если оно еще и не подготовленное. У меня в 18квм баса до жопы. И не выперает ничего))
Зачем тогда на себя направляешь?
Я от себя слегка отвернул. Но слушал и так. Они сам пишут про сч купол так, особенность у него такая. А на себя что бы фокус точнее был, но были рекомендации, что и отвернуть слегка можно, типа для комфорта, а не для работы. Но сильно отвоарачивать - фигня конечно выходит.
Те все таки угол узкий… у сч
Кость,любые АТС и не только с СЧ куполом ограничены по направленности в меру))))мониторы всё таки)
Да я не против. И это нормально. Я к тому что вопросов к расположению атс что к 50 и тем более к 100 было двольно много, постоянно крутил двигал. К этому надо быть готовым. И покупать вслепую надо крепко подумать. С учетом цен вторички или точнее сложности продажи по нормальному ценнику и цен на новые даже с учетом спец предложений.
Вертикальный да, горизонтальный нет. Это означает что тоналка и прочее не уплывают если ты перемещаешься по горизонтали. Понятно что лучший фокус только в центре
Константин согласен ! Когда в твоём доме стоят АТС, движуха обеспечена , их хочется двигать , чтобы ловить мэджик, хочется менять компоненты в поисках лучшего звука.
Звук есть , но хочется большего, нет спокойствия .
Тут мысль пришла в голову . А почему АТС так любят стоять в студиях. А ответ простой, потому как самые востребованные проектировщики студий- это англичане . Просто мода такая . И естественно они ставят свою акустику . А Билли уж договорился какую :).
Мысль натолкнула когда посмотрел прекрасное видео интервью в ветке AN с звукорежисером. Студию Мосфильма где АТС англичане проектировали
А бОльшая часть музыки откуда у нас?))
Да да , англичане лобают попсу:) и рок . Хорошо что в классику не лезут . Кстати узнал, что новый концертный зал «зарядье» не англичанин проектировал , надо сходить.
Юра, ну это конечно же не так…
Ваще никогда атс не крутил, всегда всё устраивало, а лучше для меня их нет)
Англичане пишут лучше всех…почти всегда)))и в классику лезут, а почему им не лезть туда?
Ну блин, ваааще. ))
Немцы, ну америкосы немного. )
Где англичане?
Decca?
Дойче Граммафон фиг переплюнешь. )
Дека…дойче…какая разница…
От конкретной пластинки и производителя зависит…
У всех этих контор есть куча дочерних по разным странам,а там работают конкретные люди с конкретными задачами))))
Подразделений любых брендов по всем странам тьма тьмущая…Старые англичане и японцы были самые интересные и правдивые и не важно где и в какой стране этот бренд изначально зарегистрирован.
Немцы,уж точно в ауте среди англов,американцев и япов(я про CD )
Ушёл от ответа. )
При чём дочерки?
Хотя есть у меня и Декка Лондон симфонические оркестры неплохие заиси.
А так в основном Дойче Граммафон, и без фуфлыжничества. ))
