на серебре? Да ну, фантазер
При случае сделаю фото.
Почти, как у меня.
Чё, опять ехать?
Ааа
Спасибо, походу улучшеная версия с карбонизированым анодом, спецзаказ наверное. На эбее простые продаются.
А что это за лампа? Производитель?
Таки вот. Какие у кого есть сплетни?
Ну и если на гуманитарный язык перевести. Что это все значит.
It’s the first day of the Bristol HiFi Show today, and we will be presenting. for the first time in the UK, the new version of our classic and long serving MEISHU 300B integrated amplifier. Below is a brief description of what changes have been made for this new version: -
"The basic idea behind the ‘new’ Meishu was to optimise the circuit by reducing the number of components, especially in the PSU, which – if done correctly - would improve sound quality.
So, taking what we learned when developing the P4 Balanced and KEGON Balanced amplifiers, the new PSU uses only one mains transformer, one 5U4 rectifier valve and one choke. When this arrangement is optimized, thanks to very careful and precise component selection, it works extremely well, producing a very homogeneous and ‘complete’ sound.
The input and driver stage is very similar to that found in the JINRO, TOMEI and ONGAKU, with a 12AU7 and 5687 driving an in-house designed and manufactured inter-stage transformer for the best energy transfer, evenness and authority. This is the most important, fundamental upgrade over the original design.
The output transformers for the new MEISHU were designed specifically for the project by Andy Grove, and it is not an overstatement to say that they are superb. Even in its most basic version, equipped with a mix of 0.5 Watt and 1 Watt Audio Note (UK) tantalum resistors, Audio Note (UK) Standard Electrolytic capacitors, IHIB double C core inter-stage transformers and standard EI output transformers, the new amplifier sounds wonderful. Eventually we will release Level 4 and Level 5 versions, which will use improved quality components.
The Phono version of the new MEISHU uses the existing phonostage found in the M1 and M2 Phono preamplifiers, which is an excellent sounding design. For the Level 4 and Level 5 versions, we will replace this with the M3 phonostage which uses three 5670 triodes. This will be a major performance improvement, and will truly redefine the expectations of how an integrated, phonostage equipped amplifier can perform.
With its power, finesse, focus, effortless musicality and expressive tonal colour, the new MEISHU will redefine the integrated amplifier."
Отсюда:
И вообще, все это к добру или не к добру?
Только недавно, объявил 2019-ый годом 300Б в баре и вот тут сплошные новостные поводы. Полярность бы вот понять.
Экономия налицо, как бэ при том же ценнике
На щёт ценника Вы пожалуй оптимист Радослав
Ну вроде не объявлили. Или опять “математика от Петра” где минус всегда превращается в плюс.
Входная секция от самой Онгаки, а фоно как у М3 - вангую NEW Meishu будет дороже, как пить дать
Свой перечень почему с АН нескучно жить, готов расширить пунктом о том что просто невозможно не обсудить какая схема ОДНОГО И ТОГО ЖЕ аппарата лучше играет.
Ещё немного и история с превращением нутренностей ОТО будет курить в сторонке.
Сам перечень, напоминаю тут
Не знаю, слушать надо.
Один мой знакомый утверждал, что знает человека, у которого есть новодельный (очень рекламируемый Квортрупом и Грувом) Jinro и старый, “классический” Meishu. Так вот, этот человек, вроде бы, жаловался моему знакомому, что зря (мол) купил Jinro: ведь Meishu он слушает чаще - потому что Meishu музыкальнее…
Да, мне очень нравился фонокорректор в новых М3/М5 на трёх лампах. Интересно, как он будет реализован и как будет звучать в новых Meishu. Не раз уже писАл о том, что в современных Meishu (не важно, в простом, или Silver Signature) секция фонокорра была “самым слабым звеном”.
Звук изменится - сами пишут. А на счёт экономии - махнули силовик на межкаскадники, что в принципе у Пети даже дороже стоит.
Новые выходники, межкаскадники - надо внутренности смотреть, что там наворотили. Ну и по комплектухе левел 3 будет с стандартными конденсаторами - это как я понял вместо теперяшнего мейшу, может даже и цена не изменится, а вот силвер и силвер сигначе скорее всего станут 4 и 5 уровнем, со всеми вытекающими по цене.
И по фоноверсиям непонятки - нужели и их с того же кена питать будут??? Не потянет по току.
Михаил, прошу прощения что вмешиваюсь в разговор, но как я понял там Мейшу СС и Джинро
Да, уважаемый Дмитрий, именно так.
Только вот разница в цене между ними (Meishu Line и Jinro) весьма ощутимая - 9000 $.
Схема современных Meishu не претерпела сколь либо значительных изменений по сравнению с классическими аппаратами. Выходных трансформаторов вместо двух видов стало 3, и в самых первых было 2 лампы 6SN7 - по одной на канал: типа, “двойное моно”. Но, последние 20 лет выпускаются только версии с одной 6SN7 в предах. И ещё переключение источников (и выходов на запись) было заведено на заднюю панель с помощью трубок. Это всё практически “косметические” изменения.
Теперь, по заявлениям, будет многое “перепахано”.
Не знаю, пойдёт ли это на пользу? Доживём, посмотрим/послушаем.
