Приехал из Японии,переведен штатно на 230 вольт,состояние без видимых следов эксплуатации,без ремонтов и вмешательств,коробка,паспорт,силовой кабель. Стоимость 220000 рублей. В наличии! Г. Саратов. +79172176297 Отправлю чем угодно,куда угодно.[Guaranteed specifications are measured according to EIA standard RS-490.]
mmmmm Continuous Average Output Power (20 - 20,000 Hz)
Stereo operation 400 watts per channel into 1 ohm (✽)
(both channels driven) 300 watts per channel into 2 ohms
150 watts per channel into 4 ohms
75 watts per channel into 8 ohms
Monophonic operation 800 watts into 2 ohms (✽)
(bridged connection) 600 watts into 4 ohms
300 watts into 8 ohms
Note: Load ratings marked ✽ apply only to operation with music signals.
m Total Harmonic Distortion Stereo operation (both channels driven)
0.05%, with 2-ohm load
0.02%, with 4 to 16-ohm load
Monophonic operation (bridged connection)
m Intermodulation Distortion 0.005%
m Frequency Response At rated output: 20 ~ 20,000 Hz +0, –0.2 dB
At 1 watt output: 0.5 ~ 160,000 Hz +0, –3.0 dB
m Gain (GAIN selector in MAX position)
28.0 dB (stereo and monophonic operation)
m Gain settings MAX, –3 dB, –6 dB, –12 dB
m Output Load Impedance Stereo operation: 2 to 16 ohms
Monophonic operation: 4 to 16 ohms
[★ With music signals, load impedances of 1 Ω (stereo) or 2 Ω (mono) can be driven.]
m Damping Factor 150
m Input Sensitivity Stereo operation 0.98 V for rated output
(with 8-ohm load) 0.11 V for 1 watt output
Monophonic operation 1.95 V for rated output
m Input Impedance Balanced: 40 kilohms
Unbalanced: 20 kilohms
m Signal-to-Noise Ratio 120 dB (GAIN selector in MAX position)
(A-weighted, input shorted) 125 dB (GAIN selector in –12 dB position) At rated output
m Output Level Meters Logarithmic scale, with off switch
–50 dB to +3 dB (dB/% Scale)
m Power Requirements AC 120 V/230 V (Voltage as indicated on rear panel) 50/60 Hz
m Power Consumption 55 watts idle
480 watts accordance with IEC 60065
m Maximum Dimensions Width 465 mm (18-5/16”)
Height 180 mm (7-1/16”)
Depth 425 mm (16-3/4”)
m Mass 24.0 kg (52.9 lbs) net
28.0 kg (61.7 lbs)
